Author Topic: Troyphy truck  (Read 85171 times)
Re: Troyphy truck
« Reply #75 on: January 06, 2017, 09:00:25 AM »
smike knows better, I haven't ever touched that yet.
it's mostly effort though.
bypasses are easier to tune, that's the major benefit to them.
Re: Troyphy truck
« Reply #76 on: January 06, 2017, 09:56:22 AM »
seal kits, probably a few shims depending on what they need and a gallon of oil would do it for 100$ or so.  They look well used, and are blues the economy performance level
do i only see one compression and one rebound adjustment on the bipass?
Re: Troyphy truck
« Reply #77 on: January 06, 2017, 10:46:07 AM »
I should have looked closer, they do look pretty well-used. And yeah, 2 tube. That's pretty strange too. Makes 1500 seem pretty steep.
Re: Troyphy truck
« Reply #78 on: January 06, 2017, 11:34:53 AM »
you still have some air shocks for sale?  Wolfi looking for cheap options on the front of his FJ doing a link swap right now
Re: Troyphy truck
« Reply #79 on: January 06, 2017, 11:43:04 AM »
yeah looks like 2 tube, must not be uncommon for desert ppl ,i see other 2 tube for sale ranging from $900-1100. so all things considering ill hit him with $1300 see what happens
yeah i still have my air shocks was gonna throw them on cl today and see what happens
Re: Troyphy truck
« Reply #80 on: January 06, 2017, 11:47:28 AM »
what are the air shocks specs and cost?
Re: Troyphy truck
« Reply #81 on: January 06, 2017, 12:04:54 PM »
2.0 i think they are 18" , do you measure eye to eye or total overall length? support 1000lbs a corner, new on kustom1 $270 asking $700 but would take 600
Re: Troyphy truck
« Reply #82 on: January 06, 2017, 12:16:29 PM »
18" would be the travel, should match the amount of shaft showing at full extension.
length measurements are taken eye to eye extended and collapsed. sometimes easier to look up than measure.
Re: Troyphy truck
« Reply #83 on: January 06, 2017, 12:55:14 PM »
o, you have 4  he just needs a pair
Re: Troyphy truck
« Reply #84 on: January 06, 2017, 12:58:50 PM »
I'd sell 2 of them. Kinda works out cause 2 are still on the buggy
Re: Troyphy truck
« Reply #85 on: January 14, 2017, 07:36:31 PM »
progress
what a pain to get this engine to fit, had to relief cut the frame spread it open fish plate it and still had to notch to get the header to fit
shocks have been purchased
is this an acceptable amount of chain movement or should it be replaced?
Re: Troyphy truck
« Reply #86 on: January 14, 2017, 09:21:38 PM »
lol wow
turn those babies upsidedown and cross them over the motor!
chain looks fine- why is the timing cover pulled lol
Re: Troyphy truck
« Reply #87 on: January 14, 2017, 10:24:35 PM »
no room above the motor either, the intake is so tall on the 5.8 im hoping i even mounted it low  enough to not have to modify the hood
motor got stripped of everything to make it easier to clean and paint it eventually, thankfully i did because the cover had a crack on the inside. new cover ,oil pan,water pump,gaskets  and starter sitting on a shelf. it crazy the cost difference between sbf and sbc
Re: Troyphy truck
« Reply #88 on: April 02, 2017, 05:37:29 PM »
progress
Re: Troyphy truck
« Reply #89 on: May 04, 2017, 10:09:05 AM »
I was wondering how long before the seo link spamming started from our new offshore friend.
