Author Topic: Troyphy truck  (Read 85248 times)
Re: Troyphy truck
« Reply #135 on: May 23, 2019, 12:43:03 PM »
ya but the caliper bracket mounting in this case is part of the knuckle....
Re: Troyphy truck
« Reply #136 on: May 23, 2019, 12:59:37 PM »
https://www.pirate4x4.com/forum/ford/798413-help-id-my-dana-60-calipers.html
not a 1/2" off.
you have the thin race PN
get the thicker race PN
will move the hub out .125"
thought i had the PN but dont have them.  we went though this same issue with Joes TJ
Re: Troyphy truck
« Reply #137 on: May 23, 2019, 01:26:18 PM »
Change your inner bearing cups from 382S to 382A to push hub out 0.173" and make room for rotor.
Timken 382S
C - Cup Width
0.6250 in
https://cad.timken.com/item/tapered-roller-bearings---single-cups/tapered-roller-bearings---single-cups---imperial/382-s
Timken 382A
https://cad.timken.com/item/tapered-roller-bearings---single-cups/tapered-roller-bearings---single-cups---imperial/382a
C - Cup Width
0.7982 in
Re: Troyphy truck
« Reply #138 on: May 23, 2019, 01:41:33 PM »
Bearing cups are 382a
Re: Troyphy truck
« Reply #139 on: May 23, 2019, 01:48:11 PM »
Sheeeeeeeeeit
Sure is. and already has the thicker race.
hmm
Re: Troyphy truck
« Reply #140 on: May 23, 2019, 01:53:12 PM »
i assume you actually pulled the cup out and read the number or measured it....
hmmm dont know then!
Re: Troyphy truck
« Reply #141 on: May 23, 2019, 01:59:31 PM »
Yes. Went to carter St and got a bearing with no change.went back for the race but their national238a is same as my timken328a
So that leaves the spindle and the shoulder the bearing rest against,ciuld it be possible there's a spindle that's a 1/4" longer, how could I even find that out?
Re: Troyphy truck
« Reply #142 on: May 23, 2019, 02:01:17 PM »
Here's a dumb thought...
How thick is the factory splash shield?
Re: Troyphy truck
« Reply #143 on: May 23, 2019, 02:06:36 PM »
16guage at the most,i had same thought but that eBay listing doesn't have them installed either
Re: Troyphy truck
« Reply #144 on: May 23, 2019, 02:52:23 PM »
are you missing the big snap rings in the hub?  cant remember if those are in 60 or in 14bolt hubs.  the inner race could be sitting on a casting instead of sitting on a snap ring
Re: Troyphy truck
« Reply #145 on: May 23, 2019, 04:15:38 PM »
Race sits against a casting lip
If you need to return something to Amazon and select ordered wrong part it's a $6 charge, if you go back 2 pages and make up some b.s. excuse  the return is free
Re: Troyphy truck
« Reply #146 on: May 25, 2019, 06:22:39 PM »
Wrong rotor is my guess.
You’re welcome to try my ‘correct’ rotor & hub assembly I took off my truck.
Re: Troyphy truck
« Reply #147 on: July 02, 2019, 08:59:51 PM »
little by little, had to remount new radiator due to being larger then the one used for mock up,coolant lines ran. Decided seats mounted to high, ripped it all out and remounted lower, and harnesses mounted in.Oil cooler and filter relocation kit mounted. Fuel return bulkhead installed in fuel cell and pressure/return lines ran and pump installed. Started to dig into the harness and find the necessities. I have about 85% of parts needed to finish have to go to the bank tomorrow and pay off my amazon card and order the rest. Still a lot to do
Re: Troyphy truck
« Reply #148 on: July 03, 2019, 09:33:22 AM »
holiday tomorrow!
Re: Troyphy truck
« Reply #149 on: July 03, 2019, 10:07:15 AM »
is this what you need battery cables for?
starting a v8, idk about winch, and is the battery in the bed?
probably 2ga
