Author Topic: 571 Racing punchlist time  (Read 55282 times)
Re: 571 Racing punchlist time
« Reply #90 on: April 13, 2012, 06:44:05 PM »
Blew a rear wheel off prerunning    working on it.  Easy but dusty course.
« Reply #91 on: April 13, 2012, 06:58:12 PM »
Blew it off?
« Reply #92 on: April 13, 2012, 07:54:42 PM »
Loose lug nuts.
« Reply #93 on: April 13, 2012, 08:10:46 PM »
571 rides pretty good on 3 wheels.  That was a long walk back to get my tire.
« Reply #94 on: April 13, 2012, 08:20:47 PM »
how far did you keep going?
« Reply #95 on: April 13, 2012, 08:50:27 PM »
About 50 yards.   Never even felt a change in the car.  Honestly I thought a branch was wrapped in the front shaft.
« Reply #96 on: April 13, 2012, 08:53:23 PM »
The fan also has a 30 and 10 amp fuse jammed in.to it ha.
« Reply #97 on: April 18, 2012, 01:23:13 PM »
thought randomly occurred to me, so I checked...
autometer has at least a dozen full sweep voltage gauges.
they also have 60a ammeters, and one could be run with that small an alternator - but I'd be looking to upgrade the alt if it ever fails so I wouldn't go with that.
« Reply #98 on: April 19, 2012, 10:08:38 AM »
wow, the housing bolts and all 5 of the electrical connection bolts were all loose on the actual starter motor.  the starter mounting bolts were actually tight.  Tightened all and re shimmed starter. good to go.
cleaned and mounted 4 KMC beadlock wheels on the new KRTs
« Reply #99 on: April 19, 2012, 11:23:37 AM »
Let's see a picture of 571 with the new running gear.
« Reply #100 on: April 19, 2012, 11:26:58 AM »
smike..
I may give your fluids to Mike... im seeing him in 30
« Reply #101 on: April 19, 2012, 12:14:37 PM »
sounds good.
« Reply #102 on: April 19, 2012, 02:33:36 PM »
bet the lose connections didn't help low voltage do magic. glad it was an easy fix.
fluids didn't happen.
