Author Topic: 571 Racing punchlist time  (Read 55269 times)
« Reply #75 on: April 09, 2012, 10:39:58 PM »
The m4wd quart crate!
Re: 571 Racing punchlist time
« Reply #76 on: April 10, 2012, 12:38:13 AM »
finish window net install
replace master disconnect bipass
Mount new tires on new wheels
Front end rebuild with Solid Knuckles
New longer tie rod
driver side poly bushings in links
Profender 2.5s install
motor trans diffs case fluids
front shaft?
rear fan re wire non hack and to HI speed
sew belts
throttle linkage?
« Reply #77 on: April 10, 2012, 12:38:39 AM »
« Reply #78 on: April 10, 2012, 04:37:27 PM »
Hutchins Rage Pro in a box and eastbound, be here Thursday ctsy of FedEx.
You need a hand tonight? I'll be late if you do, I have a couple HHRs to shuffle off to Buffalo; things just fell into place. Looks like it may be a wet drive.
« Reply #79 on: April 11, 2012, 12:16:24 AM »
New longer tie rod
front shaft?
sew belts
shit, grind out center of spare
sweet fluids containers made, tool bags packed and strapped, full race prep status minus shoulder harnesses that i some how need to find time to have re sewn.
« Reply #80 on: April 11, 2012, 04:18:17 PM »
Wow there is a huge hydroponics place where chips shop was!   The guys at snyders said to say hi if he is ever back to finish his jeeps!
« Reply #81 on: April 11, 2012, 04:24:10 PM »
Are his jeeps stilk there
« Reply #82 on: April 11, 2012, 04:25:33 PM »
No he has a new shop over by me
« Reply #83 on: April 11, 2012, 04:26:00 PM »
no they are in chips shop in Henrietta off Leigh station rd
« Reply #84 on: April 11, 2012, 04:26:13 PM »
just beat me...
« Reply #85 on: April 12, 2012, 01:03:58 AM »
tire pressures checked, driver rear at 12lbs, all rest holding 22psi
all yoke strap bolts checked
winch switch swapped
re sewn harneses bolted up
goggles cleaned and loaded
trailer cleaned and loaded
buggy loaded
lets go racing.
 8)
« Reply #86 on: April 12, 2012, 11:28:59 PM »
fueled and hooked.  running into work for a few hours and then heading south...
« Reply #87 on: April 13, 2012, 07:45:53 AM »
God spede, racers!  Drive it like you stole it!
« Reply #88 on: April 13, 2012, 08:40:54 AM »
Have fun and hope the neck brace works well
orange anchor
« Reply #89 on: April 13, 2012, 10:34:16 AM »
good luck Smike keep the radio tuning to a minimum you know how those 5' tall stone just jump out.
