Author Topic: 571 Racing punchlist time  (Read 55282 times)
Re: 571 Racing punchlist time
« Reply #60 on: April 07, 2012, 09:16:32 PM »
Yokes*
Full fluid change on this guy done today on the lift.  That was nice.
« Reply #61 on: April 07, 2012, 09:24:50 PM »
I was going to do that but my diff drains are no longer useable
« Reply #62 on: April 08, 2012, 11:42:50 PM »
man race prepping on a lift is SOOOOO much easier
« Reply #63 on: April 08, 2012, 11:47:16 PM »
added yearly quart of gear oil to 205 and welded 3/8" rod to the mounting bolts to lock them in as we have threatened for 2 years to do all 4 finer loose 1/2".  Fixed trail hack on rear fan wiring and swapped to HI speed, added safety padding to leg and arm bitters, fluid spatter protection from coolant plumbing improved, changed out bad bladders, fixed leaky 02 bung.
sat in helmet and new hans making vroom vroom noises!
« Reply #64 on: April 08, 2012, 11:49:13 PM »
finish window net install
replace master disconnect bipass
Mount new tires on new wheels
Front end rebuild with Solid Knuckles
New longer tie rod
driver side poly bushings in links
Profender 2.5s install
motor trans diffs case fluids
front shaft?
rear fan re wire non hack and to HI speed
sew belts
throttle linkage?
« Reply #65 on: April 08, 2012, 11:57:42 PM »
shit, grind out center of spare
« Reply #66 on: April 09, 2012, 10:53:06 AM »
not a bad list...
« Reply #67 on: April 09, 2012, 11:48:09 AM »
i think tonight will be throttle linkage and maybe a front skid that i have been eyeing up.
loathing changing out some from bushings.
Also skimped and didnt pick up inner axle seals yet, driver side really needs it on the front....
« Reply #68 on: April 09, 2012, 11:48:53 AM »
really wish i had gotten wheels.  Last years tires are bald ass
« Reply #69 on: April 09, 2012, 11:54:11 AM »
load shit up and take it all to Tom's tire machine? or Kost?
you put the front together and it's got to all be torn down again to do seals or will that be "easy"?
« Reply #70 on: April 09, 2012, 11:59:10 AM »
had to drive it over to the lift and i wanted to test brakes and such so it got driven a bit and then parked in the lift bay.
im not putting new tires on shit beat H2's, which 3 have slime in them now also.
« Reply #71 on: April 09, 2012, 12:06:18 PM »
Matt at solid says tough tatas try a different caliper or a different brake line that is less obtrusive
shitty
« Reply #72 on: April 09, 2012, 12:48:37 PM »
in pretty good shape over all though, getting to the point where a couple extra eyes to pick out some weak points and knock out some fixes...
i think 571 is in the best shape ever right now!
« Reply #73 on: April 09, 2012, 01:14:01 PM »
That's saying a LOT, she's been in 3rd (?) place shape before ;D
Pathetic, can't remember if it was 3rd or 4th
« Reply #74 on: April 09, 2012, 02:11:12 PM »
3rd!  i got 88$ and a trophy!  behind miller, badulchis
