Author Topic: 571 Racing punchlist time  (Read 55340 times)
Re: 571 Racing punchlist time
« Reply #30 on: March 26, 2012, 04:34:26 PM »
i think im going to order a HANS also.
i dont understand the details but they are are in still ill look more tonight.
« Reply #31 on: March 26, 2012, 04:34:33 PM »
I don't need rolls, mine jammed with mud or misfeed and the ratchet stripped.
« Reply #32 on: March 26, 2012, 04:37:20 PM »
o ok, just list anything else we should look at getting, ill get the order together tonight.
« Reply #33 on: March 26, 2012, 04:44:59 PM »
not that I can think of...
« Reply #34 on: March 27, 2012, 01:00:01 AM »
lots o money to summit.... horah
« Reply #35 on: March 27, 2012, 08:26:32 AM »
I did the same thing last night. UPS says some of it will be here tomorrow, gotta love Summit.
« Reply #36 on: March 28, 2012, 01:28:29 PM »
Your new springs will be here today.
« Reply #37 on: March 29, 2012, 07:39:27 PM »
new springs and coils in hand.
there is a summit box also in the truck.
front parts should be here with arie tomorrow.
id like to get the front end done this weekend, and then start looking at shocks and such.  Still havent decided if the new 2.5's will be on for the first race.
Also have the wheel situation that blows.
« Reply #38 on: April 01, 2012, 11:34:53 PM »
finish window net install
replace master disconnect bipass
Mount new tires on new wheels
Front end rebuild with Solid Knuckles
New longer tie rod
driver side poly bushings in links
Profender 2.5s install
motor trans diffs case fluids
front shaft?
rear fan re wire non hack and to HI speed
« Reply #39 on: April 02, 2012, 02:58:18 PM »
new knuckles are sexy.  i need a couple 7/8" bolts and i am not going to Hen FNL again, lol
« Reply #40 on: April 02, 2012, 06:21:33 PM »
the seals we had in ROC were questionable.. looked liked they been returned a few times..
you'll have 3 tomorrow AM
figured you would be busy tonight with the lift anyway..
« Reply #41 on: April 03, 2012, 08:37:51 AM »
i should probably get two cases of ATF also.  used the shops stock and some of the trailers to fill the lift up last night!
« Reply #42 on: April 05, 2012, 11:56:06 PM »
New longer tie rod
front shaft?
Re: Re: 571 Racing punchlist time
« Reply #43 on: April 06, 2012, 08:09:01 AM »
 Those knuckles we're damn sexy. I assume they'll hold up much much better. not to say that your custom ones did not hold up just as well especially for the price you paid to make those
 You got everything ready to go?
 I'm still hoping I can make it down for the race at least to pit... even if I don't have a jeep 2 wheel
« Reply #44 on: April 06, 2012, 08:20:52 AM »
still have quite a bit to do
