Author Topic: MMTR Mini  (Read 121434 times)
Re: MMTR Mini
« Reply #90 on: March 18, 2015, 04:11:59 PM »
Albany could kill the whole thing - NH probably shouldn't have registered it in the first place, and it's deep into grey here, so we'll see.
I can't wait to get the valve seals replaced and hopefully kill the oil smoke.
It needs front amber and rear red side marker lights on it in case it gets inspected for compliance... It also needs a broken rear turn signal lens replaced, a rear plate light installed, and the backup light fixed for inspection. Speedo cable or speedo is broken. Governor isn't disabled, but 4th gear is permanently locked out on my transmission so even though it's governed to 25, it'll probably only do 30-35 at redline if I bypass that (which from what I read requires doing a standalone ignition, bypassing a fuel pump relay, and make a new distrib holddown to set advance properly - or from what I was told at purchase, swapping in the distributor he gave me).
I love tooling around in the little thing, not so sure how I'll feel about that with normal size traffic around me.
Re: MMTR Mini
« Reply #91 on: March 18, 2015, 05:14:59 PM »
You are not allowed to name your own junk...
Re: MMTR Mini
« Reply #92 on: March 18, 2015, 05:20:36 PM »
I didn't name it. DMV named it.... :)
Re: MMTR Mini
« Reply #93 on: March 18, 2015, 06:17:58 PM »
Gusgus says "bring it on Albany!"
Re: MMTR Mini
« Reply #94 on: March 18, 2015, 06:21:53 PM »
not to suprised. iirc didnt a guy in the club have one of these he would drive to wp, he would show up on street tires and put atv tires on when he got there
Re: MMTR Mini
« Reply #95 on: March 18, 2015, 06:37:28 PM »
Good stuff mike.
Re: MMTR Mini
« Reply #96 on: March 18, 2015, 06:47:29 PM »
Yes, wheeled a101 with him
Re: MMTR Mini
« Reply #97 on: March 18, 2015, 06:50:50 PM »
He knew nothing about how it got plated.
Re: MMTR Mini
« Reply #98 on: March 19, 2015, 06:16:38 PM »
Re: MMTR Mini
« Reply #99 on: March 19, 2015, 07:27:45 PM »
Wtf don't give him ideas.
Re: MMTR Mini
« Reply #100 on: March 19, 2015, 07:41:47 PM »
in sure there are parts out back!
Re: MMTR Mini
« Reply #101 on: March 19, 2015, 07:45:05 PM »
Do not need...
Re: MMTR Mini
« Reply #102 on: March 19, 2015, 07:45:25 PM »
True...
But: do not need.
MMTR Mini
« Reply #103 on: March 22, 2015, 06:24:22 PM »
161-151-145 compression. Not great but enough that I expect valve seals to fix 'er up.
Plugs & mfgd socket
Re: MMTR Mini
« Reply #104 on: March 22, 2015, 06:52:49 PM »
That's a sweet tool!
