Author Topic: MMTR Mini  (Read 121345 times)
MMTR Mini
« on: March 01, 2015, 11:19:38 AM »
Needs: ebrake freed up, new alt belt, fix/ figure spaghetti shifter issue. Looks like loose bushings all over.
Check timing belt, plugs, clutch cable, choke. Cold start was very difficult.
Insure it
Plate it?
Paint it
Parts Notes:
Toro cross-reference stuff? http://minitrucktalk.com/threads/interesting-mitsu-engine-info.934/#post-5464
full parts breakdown, english: http://www.partsbase.org/mitsubishi/mighty-mits-mmna-us-1988-1995-u14t-qhpdl2m/
« Last Edit: March 03, 2015, 10:58:30 AM by mr.mindless »
Re: MMTR Mini
« Reply #1 on: March 02, 2015, 10:26:34 AM »
so it's stuck in reverse since I parked it at home the first time.
The shitty shifter seems to have made me fight the shift finger right out of the reverse fork leaving it with reverse engaged. Found a parts drawing that shows how the mechanism works. Probably have to pull extension housing off the trans to fix. It's like a rear shifted Toy case with the linkages coming in the back side. Hopefully simple matter of clean it up, drop the driveshaft, I think pull the rear trans mount, split the case, shift it out of reverse with the shift rail, and be all set.
Just what I was hoping for with a new purchase!
Mini - 0
Ranger - 1 (it runs/drives/starts/forwards and backs all on its own)
mowzer - (-1) (minor electrical fire last night. undiagnosed. I ripped the battery out and let it sit. fawk me.)
Re: MMTR Mini
« Reply #2 on: March 02, 2015, 10:27:45 AM »
Re: MMTR Mini
« Reply #3 on: March 02, 2015, 10:28:29 AM »
Re: MMTR Mini
« Reply #4 on: March 02, 2015, 10:32:49 AM »
Ooh, I just had a thought - I wonder if I can coax the reverse fork back through the reverse light switch hole. that'd be pretty ideal!
Re: MMTR Mini
« Reply #5 on: March 02, 2015, 10:37:31 AM »
can we see pictures of this thing or just the broken bits?
Re: MMTR Mini
« Reply #6 on: March 02, 2015, 10:43:58 AM »
once it's back out of the mini garage :)
Re: MMTR Mini
« Reply #7 on: March 02, 2015, 01:57:46 PM »
pulled the switch, can pry but not moving easily.
mild concern about getting the linkages set properly for reassembly, but I think I will have to split it to fix it :(
Re: MMTR Mini
« Reply #8 on: March 02, 2015, 02:17:18 PM »
I can only imagine the amount of stuff you are going to accumulate by the time you are 50. You are going to need some serious property  :)
Re: MMTR Mini
« Reply #9 on: March 02, 2015, 02:48:44 PM »
Kim's dad has like 1200+ acres in the north country.... I just need barns :)
Re: MMTR Mini
« Reply #10 on: March 02, 2015, 03:36:49 PM »
Details?
Manuf model year engine 4wd tire size etc...
Re: MMTR Mini
« Reply #11 on: March 02, 2015, 05:23:35 PM »
Put a ring on it and let's go camping and cut some trails.. WTF. That's like what I'm looking for..
Re: MMTR Mini
« Reply #12 on: March 02, 2015, 05:24:28 PM »
 :o
Re: MMTR Mini
« Reply #13 on: March 02, 2015, 10:33:17 PM »
Drove it to work. Sorry no pics yet. No ponies and lots of oil smoke. Made it through the snow on the trail bridges better than I expected. Not sure how it'll do with softer snow on warmer temps.
Stalls a lot when cold. Probably need to bump idle up a bit. Reminded me why carbs suck...
Re: MMTR Mini
« Reply #14 on: March 03, 2015, 07:57:09 AM »
trail bridges?   :o
