Author Topic: MMTR Mini  (Read 121347 times)
Re: MMTR Mini
« Reply #240 on: May 15, 2024, 08:11:54 AM »
I need to do that to the Willys tank if I ever want to get it running again, will be interested if that works
Re: MMTR Mini
« Reply #241 on: May 27, 2024, 06:33:50 PM »
Mitsubishi must employ child labor to put the pickup screen on the draw tube on this fuel tank.
And yes I did snap 2 of the 3 studs on the level sender. Studs don’t stick through. Dual wall on top it seems. Will be fun to drill those out
Or I just get a big hole saw out and give room to work and fix 2 problems. That may end up the way to go. No existing flat spot of course.
Re: MMTR Mini
« Reply #242 on: May 27, 2024, 08:05:58 PM »
want a cobalt tank?  toss that in the trash just put a boat tank or something modern in it lol
Re: MMTR Mini
« Reply #243 on: May 28, 2024, 07:01:54 AM »
Worth looking at. Changing to draw straw for low pressure frame rail pump and making filler and mounts work seem like similar level of work overall.
Pic and dimensions?
All the car tanks I’ve had were way too wide. Nothing still around, I haven’t held onto them.
Re: MMTR Mini
« Reply #244 on: May 28, 2024, 04:56:53 PM »
Re: MMTR Mini
« Reply #245 on: August 18, 2024, 09:55:47 PM »
Like 3 hours of labor washing and rinsing and prepping and rinsing and sealing.
It’s curing now.
Wash with soap and water
Rinse with water
Wash with “metal wash”
Flush with water
Wash with Muratic acid
Double flush with water
Wash with “fast etch”
Wash with acetone x2
Coat with sealer and keep rotating and then lace to cure with some low pressure forced air.
And after 20m of that I’m worrying about condensation because the half psi air I’m putting in is expanding right at the tank and it’s making it cold and it’s sweating. Hopefully it’ll work out. If not it’ll be hard to fix.
Probably would have been easier to wash and cut out the rust and weld on a patch - but that could still have a pinhole, so…. Yeah.
Hopefully can have my yard cart back and clean up a million things.
Anyone have a hitch laying around that I could weld on?
Re: MMTR Mini
« Reply #246 on: August 19, 2024, 09:00:33 AM »
I have a receiver, as in the just the receiver piece.
Re: MMTR Mini
« Reply #247 on: August 19, 2024, 10:37:35 AM »
I've got some other material to build a hitch from, if you've got a receiver. that'd be helpful...
Re: MMTR Mini
« Reply #248 on: August 22, 2024, 11:14:55 PM »
reassembled and out of the shop
