Author Topic: MMTR Brolite  (Read 111126 times)
Re: MMTR Brolite
« Reply #255 on: September 20, 2016, 03:32:23 PM »
shocks say delivered!
Re: MMTR Brolite
« Reply #256 on: September 21, 2016, 09:46:41 AM »
shocks in and look good.  Will and I working on brolites tonight at M4
Re: MMTR Brolite
« Reply #257 on: September 23, 2016, 09:27:43 AM »
need to get bumper steel, radius arm bolts.
springs will be here Weds, I fucked up and didn't push the button late last week, I guess - fixed that wednesday night. Hopefully will have everything else taken care of this weekend and just need to button up the spring install late next week, we'll see how things go this weekend.
Re: MMTR Brolite
« Reply #258 on: September 23, 2016, 03:56:43 PM »
feel free to grab shocks from shop anytime.  working in shop tonight, gone sat and sunday all day.
Re: MMTR Brolite
« Reply #259 on: September 26, 2016, 09:34:36 AM »
- passenger ball joints done, that was a bit of a bitch, should have brought the knuckle to a press.
- springs out, radius arms 3/4 of the way out.
- 3 new radius arms prepped for 1/2" bolts. All gave me the same trouble drilling at the weld as the ones in the truck now did, I wonder if the arm might be hardened steel and the pin of the shock stud that goes through to be welded is closer to 7/16? That wouldn't make sense since the base of the stud doesn't fall off after drilling to 1/2" though. I had to open up the back side with a burr, could not drill. Need to sharpen half a dozen drill bits now...
- 2 radius arms are set for double shear and just need paint.
- restocked bolt bins
- did a minute of lathe work on a steering coupler and picked up shocks
- cut out more rotted rust from bottom of front clip. new qty of front body mounts: 0
needs:
- rewire everything from the stock ignition switch
- remove column, mounts; mount quickener, extend steering shaft, weld quick release
- rock sheild for radiator
- permanently wire and mount shift light
- install seat
- grab parts from Arie
- R&R steering box. my puller doesn't clear the box, I might just cut the casting to get clearance for the puller to grab the pitman arm unless someone has a better idea
- R steering pump
- change up rear shock mounts to 1/2" double shear & install shocks
planning to take WRF of this week off.
Re: MMTR Brolite
« Reply #260 on: September 26, 2016, 09:45:49 AM »
i should have shared my method
flap wheel weld on back of stud, punch stud out.  weld 7/16" (actually a tight 1/2" hole) washer on shock side, weld 1/2" top lock on back side.  weld double shear bracket chopped from scrap box tube.  30 min or less to do the pair.
Re: MMTR Brolite
« Reply #261 on: September 26, 2016, 09:46:47 AM »
the stud hole is 5/8 after tapping it out FYI
Re: MMTR Brolite
« Reply #262 on: September 26, 2016, 10:13:33 AM »
Just hardened from HAZ I guess, then.
Re: MMTR Brolite
« Reply #263 on: September 26, 2016, 08:58:09 PM »
Trying to find belt routing info I came across this thread saying the pitman arm doesn’t interchange between power and manual boxes!  Shit.
http://www.diyelectriccar.com/forums/showthread.php/manual-steering-97-ranger-72323.html#/topics/72323?_k=qjgisg
Re: MMTR Brolite
« Reply #264 on: September 26, 2016, 09:09:04 PM »
Details on whats needed
Sounds like cj may fit?
http://www.therangerstation.com/forums/showthread.php?t=158818
Re: MMTR Brolite
« Reply #265 on: September 27, 2016, 01:25:30 AM »
rock auto says they interchange and use the same coupler.  was hoping to have parts to look at today
Re: MMTR Brolite
« Reply #266 on: September 27, 2016, 07:27:35 AM »
since you posted after midnight "today" might happen..
Re: MMTR Brolite
« Reply #267 on: September 27, 2016, 10:43:40 AM »
steering shaft should be good. Rock only lists power steering pitman arms. manual arms appear to be NLA.
hoping some of the Jeep junk you have laying around might be good, otherwise I'll just not spin the pump and run the power box for the moment and hopefully fix it for the 22nd.
Re: MMTR Brolite
« Reply #268 on: September 27, 2016, 11:04:25 AM »
that was also my plan.
the only manual pitman arm from CJ stuff i had i think gif got and it end up on the hotrod project.
will need to see what it is on ford junk.  CJ arms and drop arms def available still.
Re: MMTR Brolite
« Reply #269 on: September 27, 2016, 12:13:44 PM »
i still have the cj box.     I went with a reversed corvair steering box
