Author Topic: MMTR Brolite  (Read 94817 times)
MMTR Brolite
« Reply #270 on: September 27, 2016, 08:07:24 PM »
Found one, but in Wisconsin.
Also found my leak: PS bracket is almost touching the pressure and return lines leaving to top of the box. bad leak around one thats kinked just out of its fitting.
Re: MMTR Brolite
« Reply #271 on: September 28, 2016, 10:51:41 PM »
Droop on this thing is ludicrous. Haven’t checked ride height yet. Tomorrow morning before meetings that drag me back to work.
12” shocks out back are too long. Shackles are gonna get un-reversed. Probably will level it out with the new front springs.
Too much to do too little time as usual.
Friday can be a long day though - dropping Kim off at the airport for a 0630 flight.
Re: MMTR Brolite
« Reply #272 on: September 29, 2016, 12:10:27 AM »
method for rear shocks:
hang truck in rear by frame
attach shocks to lower mount.
fully extend shock minus 1.5"
weld bolt to cage where eye lines up
done
Re: MMTR Brolite
« Reply #273 on: September 29, 2016, 09:57:17 AM »
Shoulda gone for 2” TJ coils instead of 4”
I think I got a 4” lift from these that I didn’t need or want
I guess I’ll align to max camber and run it...
Re: MMTR Brolite
« Reply #274 on: September 29, 2016, 10:01:30 AM »
They'll probably settle a little
Re: MMTR Brolite
« Reply #275 on: September 29, 2016, 10:04:40 AM »
hmmm
cut a coil or two off the top?
Callelle
Re: MMTR Brolite
« Reply #276 on: September 29, 2016, 12:48:15 PM »
Want me to just sit on the hood for a while
Sent from my SCH-I545 using Tapatalk
Re: MMTR Brolite
« Reply #277 on: September 29, 2016, 01:28:38 PM »
Now that's funny.
Needed that laugh. Thanks.
Re: MMTR Brolite
« Reply #278 on: September 29, 2016, 09:19:22 PM »
Can’t find a pitman arm that will work. Not sure I can cobble hoses to a non broken state to loop them since the ps bracket crushed one. I guess I’ll make due if I don’t hear good news on a pitman arm measurement from gif.
Humbug.
Other than bumpers and steering things are looking good. I guess I’ll have to throw the power box back on no matter what to get over to bumper fab.
Re: MMTR Brolite
« Reply #279 on: September 29, 2016, 09:51:27 PM »
I have a flat cj and YJ drop
Re: MMTR Brolite
« Reply #280 on: September 29, 2016, 09:55:35 PM »
Manual steering? I think that’s key to the smaller shaft. Flat is good too but I can make what I need if I can get the right splines.
All power boxes checked (yj cj zj and ranger) are just shy of 1.25” od on the shaft at the top of the arm. What I’m after is ~1.1” there.
Re: MMTR Brolite
« Reply #281 on: September 29, 2016, 10:04:51 PM »
Flat pitman from a manual cj box
Re: MMTR Brolite
« Reply #282 on: September 29, 2016, 11:20:30 PM »
Humbug.
Re: MMTR Brolite
« Reply #283 on: September 30, 2016, 04:40:15 AM »
 Thanks Gif!
If there's a pitman arm that goes with that it's got a chance of being right.
I'm up for the day and about to throw the power box back on so the truck is mobile, I'll keep an eye here in case I can run out and pick something up today.
Re: MMTR Brolite
« Reply #284 on: September 30, 2016, 07:53:12 AM »
i didnt see the arm.    but i really didnt look that hard.
