Author Topic: MMTR Brolite  (Read 111126 times)
Re: MMTR Brolite
« Reply #225 on: June 10, 2016, 12:37:13 PM »
trying to reach this guy, only cheap option I located in a quickie search
http://buffalo.craigslist.org/wto/5582277474.html
Re: MMTR Brolite
« Reply #226 on: June 10, 2016, 04:46:51 PM »
delivering tomorrow. couldn't be better timing, he's driving past on his way to Pulaski. should be meeting at the Scottsville plaza around 0830.
score!
Re: MMTR Brolite
« Reply #227 on: June 11, 2016, 02:53:14 PM »
$47 for my three fucked up wheels.
Took a LOT to break down the back beads. Couldn’t dismount solo on the tire machine. Too heavy a tire.
Heading back to the shop now to get the InnerAirLocks put in the good tires and bring all the crap home.
Anyone need 14” rollers? One pair and 2 each oddballs. Planning to loose them instantly if no one needs them.
I think one of the matching pair was tubed :rolleyes:
Re: MMTR Brolite
« Reply #228 on: June 11, 2016, 02:54:56 PM »
The worse of the two bent wheels was cracked. I’d give 90% odds on cracking the other trying to straighten it so I figured I’d just get them out of my way. Saved the beadlock rings since they were fine.
Re: MMTR Brolite
« Reply #229 on: June 11, 2016, 02:55:33 PM »
Broken wheel scrapped. Tire re-mounted. 3 spare 14s now in stock.
Re: MMTR Brolite
« Reply #230 on: June 11, 2016, 03:08:06 PM »
M4 bead breaker does work!
MMTR Brolite
« Reply #231 on: September 08, 2016, 02:44:13 PM »
Have both front header panel body mounts failed. Don’t think I care.
All shock bushings completely shit. Already replaced rear upper bushings with nuts.
Front mounts are set up ~1” too short for fox shocks. Fuck. Length is 16.1”, I have been full bump at 15 +/- 1/8
EDIT: I’m dumb. I have about an inch to spare on bump and will have room for almost 4” more droop if I ever get softer longer springs on there. I knew I was mathing something wrong.
Radiator mount al-al tig is cracked on one side. So much for using the sweet easy aluminum ears forever.
Also need to plate a radius arm.
Hoping to leave around 5 tomorrow evening and bolt in shocks upon arrival.
I’d like to get rear wheel wells for saturday’s mud but odds on that have gone to zero.
I’m working on it today and tmw. Work keeps bugging me. 16 hours yesterday was apparently not quite enough.
« Last Edit: September 08, 2016, 02:54:57 PM by mr.mindless »
Re: MMTR Brolite
« Reply #232 on: September 08, 2016, 02:44:56 PM »
Re: MMTR Brolite
« Reply #233 on: September 08, 2016, 02:55:54 PM »
Edited above, fox shocks are 1” longer at full compression, thats all. I’ll have 1” of shaft showing at full bump instead of 2”
Re: MMTR Brolite
« Reply #234 on: September 12, 2016, 11:29:47 AM »
solid performance!
back to our redline discussion, remember i have 4.10 gears also in my truck
Re: MMTR Brolite
« Reply #235 on: September 12, 2016, 11:41:31 AM »
and I have NO idea what I have.
Re: MMTR Brolite
« Reply #236 on: September 12, 2016, 11:58:55 AM »
door code will have it
Re: MMTR Brolite
« Reply #237 on: September 12, 2016, 05:23:56 PM »
mike, im calling on shocks for will tonight, you want a pair of 12"s for the rear to match in the order?
Re: MMTR Brolite
« Reply #238 on: September 12, 2016, 05:30:35 PM »
yeah, do it.
thanks. lmk total
Re: MMTR Brolite
« Reply #239 on: September 12, 2016, 05:37:00 PM »
you have 10" on the front now right?
so ill get the same setup for Will  10front 12 rear
i have 12 front 14" rear because i am difficult.
