Aussie Locker BRO-LITE
13
14
15
16
19
Topic: Aussie Locker BRO-LITE (Read 43081 times)
Friendly Competitor
Friendly Competitor!
Re: Aussie Locker BRO-LITE
Reply #195 on:
September 05, 2015, 10:46:22 AM »
#BecauseBROliteneedscleanfuel
Friendly Competitor
Reply #196 on:
September 21, 2015, 08:33:53 AM »
Smike can I buy a fuel pump?
Ebay seller doesn't sell them anymore
Reply #197 on:
September 21, 2015, 09:38:11 AM »
search "E2000 fuel pump", 10 sellers on the first page under 40$ each.
we should have a few on the shelf if you need one this week
Friendly Competitor
Reply #198 on:
September 21, 2015, 10:14:36 AM »
I will need one this week just to be safe.
Fuel pressures both at idle and not running are within spec.
But I know foam made it to the pump at some point.
We found it in the post filter.
Drained fuel from cell(I don't think you could call it gasoline)
Flushed entire system.
Wiped cell again.
Installed new big ass filter pre pump.
Filter clean
Runs much better even in Junkyard injectors.
Do you still have my old injectors Mike?
Found spark plug wire on driver side cylinder #1 not fully seated on plug. Difficult to feel it seat with plastic extension.
Reply #199 on:
September 21, 2015, 10:49:37 AM »
last area of consern would be the regulator on the fuel rail- if thats stuck open or shut, it could be playing games with the fuel control.
i have your injectors in my jetta, ill grab a pump and bring tonight also. do you need anything else?
Friendly Competitor
Reply #200 on:
September 21, 2015, 01:31:10 PM »
No thanks that's all I need for next weekend. I'll order a few and give u one.
Truck runs pretty good now.
Still has a hesitation coming off idle.
May or may not address front springs. Still new stock replacements.
Removed 1 rear leaf and helper spring. Flipped shackles back to stock oreintation.
Gained almost 3 inches of droop.
Reply #201 on:
September 21, 2015, 04:57:51 PM »
That's a big droop difference
Reply #202 on:
September 21, 2015, 05:07:35 PM »
i gained about 4" droop in the front with the sway bar cut off
Friendly Competitor
Reply #203 on:
September 21, 2015, 10:39:49 PM »
LOL
Mine came out of the shop minus the sway bar.
Might try to swap in the 3-4 inch TJ lift coils Keith gave me Wednesday night.
Also, i fear the Excide battery I put in the Bro is failing.
Killed it a few times in the last few years and it doesn't seem to be too happy about that.
Placed it on 2 amp trickle charge Sunday night. I'll test it tomorrow
Friendly Competitor
Reply #204 on:
September 24, 2015, 01:10:34 AM »
Ready for war!
Reply #205 on:
September 24, 2015, 09:58:23 AM »
Reply #206 on:
September 24, 2015, 10:50:19 AM »
my race plan does not expect being pushed
Friendly Competitor
Reply #207 on:
September 29, 2015, 08:09:35 AM »
Quick glance last night before getting washed...
Bent passenger leaf spring
Bent steering
Camber is wonky
Random no start issue
Clutch stopped functioning around lap 9 and pedal wouldn't move.
Worked fine after the race and again next day.
Slave cylinder issue or clutch?
I'm not familiar at all with hydraulic clutches
Good news is the engine stayed running this time.
And MARK... our bedside mounts took a beating and held up pretty well. Woho
Reply #208 on:
September 29, 2015, 08:32:54 AM »
Is camber wonky or are spring mounts bent and ride height lost?
Friendly Competitor
Reply #209 on:
September 29, 2015, 01:13:23 PM »
Need to confirm.
Enjoying a few days of not working on jeeps or trucks right now!
13
14
15
16
19
