Author Topic: Aussie Locker BRO-LITE  (Read 50596 times)
Re: Aussie Locker BRO-LITE
« Reply #225 on: October 20, 2015, 12:44:51 AM »
Added 1 rear leaf and helper back to pack.
Rear axle moved back, max adjustable perches will allow aprox 1 inch.
Probably all I needed.
XJ springs installed in front.
With custom retainers.
Added 50psi to Shock pressures on all 4 corners.
Installed new Stock fuel filter post pump.
Added some paint to the cage.
Drive shaft work, verify alternator issue and neutral safety switch tomorrow.
Fluids check and she is ready.
Then packing some parts and tool box.
Then Buggy Prep!
« Reply #226 on: October 20, 2015, 08:46:16 AM »
beating this thing!
« Reply #227 on: October 20, 2015, 07:42:26 PM »
Apparently the yokes are not available aftermarket.
If I can't scavenge one from our spare truck I'm heading to J&J after work tomorrow.
« Reply #228 on: October 20, 2015, 07:44:55 PM »
ive picked one up from fleetpride before ,$30 IIRC ITS ASPICER PART
« Reply #229 on: October 21, 2015, 08:31:16 AM »
It's so nice having a spare truck in the back yard.
Driveshaft re installed with new joints.
Alternator still not charging after confirming smikes notes.
Nuway to deliver replacement today.
Can't wait to gut the wiring in this truck after KOH.
« Reply #230 on: October 21, 2015, 10:35:58 AM »
gutting the wiring was the best thing ever to do.
« Reply #231 on: October 21, 2015, 04:56:38 PM »
Time
Need more time in a day
« Reply #232 on: October 21, 2015, 05:10:22 PM »
amen
« Reply #233 on: October 21, 2015, 05:22:04 PM »
dropping this hawg off tonight or tomorrow?
« Reply #234 on: October 21, 2015, 09:55:47 PM »
Figured out my charging issue and then decided to use it to my advantage.
Alternator disconnect switch for the win!
« Reply #235 on: October 21, 2015, 10:39:55 PM »
Good call! :)
« Reply #236 on: October 22, 2015, 08:35:00 AM »
oh boy haha
« Reply #237 on: October 23, 2015, 09:27:07 AM »
i like the quickener
the reg cab is a pain to get in, but not terrible room for me the way you did the cage.  nice truck!
« Reply #238 on: October 29, 2015, 08:06:07 PM »
Decided to try and load the Bro on to our loading dock today.
The busted front end proved to be quite a challenge. But at least going down when it comes out will be much easier.
« Reply #239 on: April 08, 2016, 03:49:35 PM »
She fired right up today. Loaded it up on the flat bed with the help of Luigi!
Starting teardown this weekend. Mostly because we don't have gears for the LJ yet.
Forgot how much of a beating she took at Rolling W.
