Author Topic: brolite cherry pop 573  (Read 83935 times)
Re: brolite cherry pop 573
« Reply #135 on: May 14, 2015, 11:14:28 AM »
id imagine the bottom end of the spring doesnt line up with the way the ranger springs retain
« Reply #136 on: May 14, 2015, 04:17:25 PM »
I changed the springs on mine. It was not bad. Just a retaining nut on the inside bottom of the spring.
« Reply #137 on: May 14, 2015, 04:51:26 PM »
mine looks like its ny welded together pretty good!
« Reply #138 on: May 14, 2015, 09:45:50 PM »
I looked on my computer for the wiring, its not here, My papers are in my trailer somewhere.
I had to trace the wires back with a continuity tester from a the pcm connector. It took a while to get it all figured out, I have it written down somewhere in my trailer.....
« Reply #139 on: May 15, 2015, 12:13:26 AM »
ok dont worry about it.
« Reply #140 on: May 15, 2015, 11:53:18 AM »
driver window net in
wires good for now
alternator isolated so disco works
doors hung
hood hung
started working on from bump can mounts
list for sunday:
finish bump stops most importantly
pick up 4 more wheels Saturday in Waterloo
hood pins
hang fenders
rest is short list items
bumpers
pumper
misc
« Reply #141 on: May 16, 2015, 12:22:35 AM »
upside down and soaking the big hits!
« Reply #142 on: May 16, 2015, 08:14:25 AM »
Interesting...
« Reply #143 on: May 16, 2015, 11:09:50 PM »
Agreed.
I need to step up my front end bump game.
« Reply #144 on: May 17, 2015, 09:05:44 PM »
testing went well today.  steering, motor, and trans seem to not care being rapped.  surprisingly fast.  2nd into it or 3rd half in you are moving 40-50 on 235 ats
did some rollers then build another jump.  rolled it, then hit 2nd into it.  Matt claims 5' air all 4 tires, the lip of the jump to impact was about 25'
took it like a champ.
shock tune fells GOOD
« Reply #145 on: May 17, 2015, 09:12:37 PM »
So bummed I missed the big air!
Glad to hear all is good.
She looks like a podium finisher fosho!
« Reply #146 on: May 17, 2015, 09:19:47 PM »
need to make a front skid so we dont drag 100lbs of sod along after a good nose dive
« Reply #147 on: May 17, 2015, 11:02:20 PM »
235s seem more reasonable... No 35s tried?
« Reply #148 on: May 17, 2015, 11:34:27 PM »
ill have to change clutch master to a different style and remove the firewall bulk head connectors before the 35"s are able to be used.
« Reply #149 on: May 18, 2015, 11:39:34 PM »
front bumper tubed out
fire ext mounted for real
fuel cel drained, non ethanol rated foam removed, ton of shit removed from cell, re assembled with yellow ethanol foam
hod prop installed
fittings acquired for water in trailer
