Author Topic: brolite cherry pop 573  (Read 83853 times)
Re: brolite cherry pop 573
« Reply #255 on: September 19, 2022, 01:43:44 PM »
swapped in an 8.8 today, relatively painless.
need to remember to gut the ebrake from the right side when i get ahold of a mini spool.
was supose to be a 4.10 but its a 3.55 booo
investigated no power steering, found cracked power steering gear, awesome.
« Reply #256 on: September 19, 2022, 02:03:23 PM »
need to grab a rear brake tee line and check spline count for mini spool
« Reply #257 on: September 19, 2022, 03:06:02 PM »
think the cracked gear is from the same hit that broke the axle?
« Reply #258 on: September 19, 2022, 03:14:52 PM »
dont think so but who knows  i started the 4th race with steering and got hit mid first lap sadly.
« Reply #259 on: August 23, 2023, 07:52:36 PM »
new steering box and spool ordered.  didnt have time to check, hope its 31spline
« Reply #260 on: August 30, 2023, 03:17:24 PM »
rear axle mini spool and rear axle brake lines installed/ bled.  8.8 swap done.
cut old pitman arm off after 1hour of failed struggle to remove, then installed it 180degrees off on the new box  >:(
left this pile on the lift in hate.
needs a ball joint also.
