Author Topic: brolite cherry pop 573  (Read 83882 times)
Re: brolite cherry pop 573
« Reply #240 on: May 19, 2021, 07:46:42 PM »
I didn’t empty one tank. But knocked a bunch off first and it saw some hose first too.
Ready to fix my radiator exposure once the seat dries out fully
« Reply #241 on: May 21, 2021, 09:04:13 PM »
mid air crash into Will at Attica damage fixed
Hood zip tied repaired
broken fan clips replaced
cracked tubes welded
right front shock res mounted back to chassis
read for June5th
« Reply #242 on: July 09, 2021, 03:36:43 PM »
new steering pump
new maf housing (rock punched a hole in it)
new belt
air filter mount upgraded.
might finally need a new battery.  not cooperating but giving it one more over night charge try.
« Reply #243 on: July 10, 2021, 07:40:12 PM »
not 100% sure my motor isnt hurt.  got some neat noises ripping around my track.  probably fine  :o
really happy with my new track layout out back, its pretty fun haha.  need to add a jump on the back straight.
« Reply #244 on: July 10, 2021, 07:59:05 PM »
Shoulda kept the spare truck!
« Reply #245 on: July 10, 2021, 08:35:14 PM »
yup, i knew it as soon as i sold the motor i should have kept it.  o well.
« Reply #246 on: September 12, 2021, 06:19:09 PM »
lead 6? laps and cooling fan failed.  loss power and mike and jeff went around me.
Bah.
« Reply #247 on: September 05, 2022, 04:46:53 PM »
new drive shaft carrier bearing installed
2 new fuel filters
new fuel lines
new fuel
air pumper glue drying, was found broken from mount and flopping around.
hope that fixes the sputter yesterday
« Reply #248 on: September 06, 2022, 04:13:19 PM »
my truck decided it wanted a gravel box for a steering pump when i moved it today.  has to be the 5th pump its getting in 50 gals of fuel.  so stupid.
« Reply #249 on: September 06, 2022, 04:41:14 PM »
My fix to put a Jeep TC pump on looks better with every failure on another truck.
Not that it’s been on for THAT long, but still twice the life of pumps on your truck
« Reply #250 on: September 06, 2022, 05:27:33 PM »
update, its not the pump this time (possibly).  the new pulley i put on last time is now a clearance fit to the shaft, and just spins and slides on....
« Reply #251 on: September 06, 2022, 05:29:12 PM »
i have like 3 XJ pumps laying around that may be an option.  i did notice the shaft sizes are different size when i grabbed one to see if a pully swap would fix it
« Reply #252 on: September 06, 2022, 05:48:48 PM »
I don't remember if I had to buy a pulley to run or if I had a Jeep one around. I modified the existing bracket to take the TC pump, was pretty easy. the plumbing and making a resi fit were the hard part.
« Reply #253 on: September 06, 2022, 06:01:30 PM »
no local white box show stock of both in same place, actually not much stock anywhere for pumps or pullies.
dont feel like driving to Irondequoit tonight so amazon will bring both Thursday, cheaper, and no core.
might grab a second pulley and see if my pump is hosed tomorrow, then just have spare stuff for the trailer.
« Reply #254 on: September 07, 2022, 08:17:12 PM »
new pulley pressed on hard and good, steering back to working.  the new pulley was .009" smaller diameter than the one that fell off.
at the track it would have gotten welded to the pump haha
new tire grover came in today, grooved tire.  ready to load tomorrow as planned.
