Author Topic: brolite cherry pop 573  (Read 83905 times)
Re: brolite cherry pop 573
« Reply #165 on: August 27, 2015, 11:53:35 AM »
Test vehicle:
1987 Ford mustang LX
Engine size: 140 cu in.
No. of cyls: 4
Compression: 10.0:1
Ford Motorsport A-237 cam
Stock exhaust
119 HP4850 RPM 131 FT LB@ 3700
Ranger header 2.25" exhaust, turbo muffler
121 HP@4900 RPM 130 FT LB@ 3850 RPM
Pacesetter header 2.25" exhaust, turbo muffler
126 HP@4950 RPM 137 FT LB@ 3900 RPM
Speedway header 3"-2.5" exhaust, turbo muffler
147 HP@5200 RPM 151 FT LB@ 4050 RPM
« Reply #166 on: August 27, 2015, 12:19:18 PM »
That's kinda surprising
jacel861
  • Full Member
« Reply #167 on: August 27, 2015, 12:21:30 PM »
Ford choked the crap out of all the 80-90's motors. Add an intake, exhaust and if you're ambitious a better flowing exhaust port and they liven up tremendously.
« Reply #168 on: August 27, 2015, 12:59:02 PM »
i bet even just loosing the stock air box to a K&N style, and opening up the exhaust like i did is good for a good amount of power.
jacel861
  • Full Member
« Reply #169 on: August 27, 2015, 03:55:27 PM »
Yep. First rule of a fox body mustang- gut airbox.
« Reply #170 on: September 06, 2015, 11:07:53 PM »
boo.
took a pair of side cutters to the clutch MC line.  was expecting thin wall to fit on a compression AN fitting i had.  found super thick wall.  stumped on how to get this thing mated to Willwood MC but i guess im committed now.  Bah.
« Reply #171 on: September 08, 2015, 12:17:11 PM »
Would something like this work on the slave cylinder?
http://www.speedwaymotors.com/LS1-and-LT1-T56-Release-Bearing-to-AN3-Line-Fitting,25017.html?sku=5151396&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&catargetid=530009170000094869&cadevice=c&gclid=COKFybzq58cCFdKPHwodT_4DQQ
I know the rod master cylinder on my F350 had the same type of end but not sure on the slave end of things.
I think I may have the fitting still.  I ended up piecing the dodge line to the ford mc.
« Reply #172 on: September 08, 2015, 12:31:06 PM »
yes, that is the type that i would have needed before i cut the line.  would have been best to do it that way, because a second fitting was provided that matches up to that on the willwood MC
« Reply #173 on: September 23, 2015, 09:49:06 AM »
fire wall adjustments with 20lb sledge done
determined camber stance was from coil buckets being bent out, porto ram'd back in shape
added tube supports and inner bump stop inside coil
need to hang some fenders
clean out / mount air cleaner
trim front bumper
check harnesses
put back cowel
hang doors
bolt up battery tie / charge up battery
test
« Reply #174 on: September 23, 2015, 11:34:58 AM »
Yes yes yes
Let's go racing
« Reply #175 on: September 23, 2015, 11:41:22 AM »
oh and fix polarity on rad fan to blow the right direction, should help my over heating issue  haha
« Reply #176 on: September 24, 2015, 01:30:46 AM »
need to hang some fenders  80% complete
trim front bumper
check harnesses
put back cowel
hang doors
Fix Rad fan polarity
check fluids
test
« Reply #177 on: September 25, 2015, 02:27:15 AM »
looking good loaded
« Reply #178 on: September 28, 2015, 04:39:22 PM »
practice went well.  took anything i could do on the jumps fine.
Bent up steering on prelim but finished.
Fixed for main, limped off for main from electric failure.  Alt must not be charging.  next day was fine after a bit on the charger.  boo.
« Reply #179 on: September 29, 2015, 08:12:12 AM »
She looked good on the jumps.
But front end didn't appear happy about the big tires mid air!
Imagine a bad shopping cart wheel. :o
