Author Topic: brolite cherry pop 573  (Read 83942 times)
Re: brolite cherry pop 573
« Reply #150 on: May 20, 2015, 12:49:25 AM »
ready to load
legit spring retainers installed
helmet air pumper wired up and mounted.
cage gussets welded in
exhaust heat wrapped to protect front right shock
oil and filter change with lucas and 20w50
« Reply #151 on: May 20, 2015, 08:08:05 AM »
Thanks for the reminder.
I just bought oil yesterday.  Forgot the lucas.
« Reply #152 on: May 26, 2015, 12:29:19 AM »
could not have asked for anything more out of this thing other than a set of tires.
motor was rapped for 15 minutes solid with no care.  steering and shocks are great.
front beams are bent from multiple 6' air outs  finished both heats fine.
the first heat was the most fun i have had in a truck in years.  we were banging doors 3 wide in the air several times.  send main was a shit show from over watering the track and pretty much a waste of time
« Reply #153 on: June 11, 2015, 12:13:09 AM »
still waiting for 572 IN prep parts so this thing might see the lift tomorrow.
going to sift though jeep springs in the scrap pile and shoot for a 3" front lift to get the bent beams back in camber spec and run the 35 SCRs.  should fit great.
Looking at Willwood clutch master and re wire to loose fire wall bulkheads in driver front fenderwell
« Reply #154 on: June 11, 2015, 07:55:00 AM »
on my bronco 2 just used 2"square tube cut to height with a plate to hold spring on it.
« Reply #155 on: June 11, 2015, 09:19:14 AM »
i need a real spring to use all the travel i have for jumps
and you cant change the spring mounting geometry, only gusset and strengthen existing.
« Reply #156 on: July 15, 2015, 12:18:51 AM »
left outside in the rain status!
« Reply #157 on: July 29, 2015, 11:18:48 AM »
air up the tires on this thing and ripped around a couple laps on the Cartwright inn track.  she is still good to go haha
« Reply #158 on: August 07, 2015, 02:49:58 PM »
gona try some TJ springs on this guy this weekend and get the 35's back on it, get the wheel out of the firewall and move some clutch parts!
« Reply #159 on: August 08, 2015, 08:42:32 PM »
Tj springs no good.  2" longer at free length, but rate way less.  ride high was 2" lower
end up with i believe 4" lift xj springs out of the parts pile.  ride bumped up 1.5", removed sway bar and picked up 3" of down travel
Camber back in check and 35"s mounted back.  need to address bulkhead connector and clutch master.  should be good to go!
« Reply #160 on: August 10, 2015, 01:12:01 PM »
entire harness gutted from truck
working on rewire.
still need a clutch solution to make room in the driver wheel well.
« Reply #161 on: August 11, 2015, 08:49:02 AM »
not much but bs on the forums with guys bagging trucks that have the same issue.
i ordered a willwod MC and petal assembly, should fit inside the fire wall fine.  just need to adapt to whatever the Slave has....
« Reply #162 on: August 11, 2015, 09:56:03 PM »
re wire 100% complete and cleaned up.
I decided to set it up  with a disconnect and a push button.  nothing else bro style!
flip the disconnect on, hit the push start and its race ready!
« Reply #163 on: August 11, 2015, 09:59:49 PM »
SCRs throw sod like 20' and leave nice ruts
had to go patch up the lawn after the test lap holy tire man
« Reply #164 on: August 12, 2015, 11:02:08 AM »
Awesome
