Author Topic: brolite cherry pop 573  (Read 83981 times)
Re: brolite cherry pop 573
« Reply #105 on: March 15, 2015, 08:46:55 PM »
ill finish it up when the fenders are in
« Reply #106 on: March 15, 2015, 09:51:06 PM »
where is it cracked?
Center of the dent. I'll bring it by sometime for you to check out before it goes to scrap
« Reply #107 on: March 15, 2015, 10:23:31 PM »
ok
« Reply #108 on: March 15, 2015, 11:07:33 PM »
ordered
front bumps DAY-KU71091BK   http://autoplicity.com/search?searchterms=day-ku71091bk
rear bumps DAY-KU09017BK      http://autoplicity.com/search?searchterms=DAY-KU09017BK
will report back
« Reply #109 on: March 16, 2015, 01:11:03 AM »
says not intended for racing and the inserts are only good for 5k cycles,so id guess they are shot after one race, wonder if you could chuck the foam and make poly inserts to last longer
« Reply #110 on: March 16, 2015, 09:26:30 AM »
Sure you want to spend that much on a bro? ;)
« Reply #111 on: March 16, 2015, 10:35:32 AM »
new insert set is 34$  i bet properly set up they will last a bit.
« Reply #112 on: March 19, 2015, 01:12:12 PM »
fuel vent run last night
« Reply #113 on: March 21, 2015, 10:53:20 PM »
waiting on shocks!
braaaaaap!
this thing is fun to move
« Reply #114 on: April 30, 2015, 01:34:26 PM »
hit list
shock tracking shows deliver Monday
mount shocks
wire rad fan
run alternator charge wire to feed side of disconect
run supply / return / pump / wire pump
secure seat in
install harnesses
hang tins
bumpers
battery box tie down
window net
bump stops
limit straps
secondary door bolt latch
paint cage
fluid changes
8.8 install / gears
address driveline and brake conditions
« Reply #115 on: May 03, 2015, 11:11:57 PM »
hit list
mount shocks
wire rad fan
secure seat in
install harnesses
hang tins
bumpers
window net
bump stops
limit straps
paint cage
fluid changes
8.8 install / gears
this weekend this thing was great.  i drove it up to the drivers meeting and a couple times up to the porto johns and across the street.
the looks and comentary it got from line mt folk was worth the weekend.
Miller raced his.  i think he got a half a lap and double rolled with the woman in it.
talked to him before the race and checked out his car.  nothing more than ours, got some shock mount ideas and some other ideas.
« Reply #116 on: May 04, 2015, 09:30:42 AM »
Robbie said he looked over his shoulder to check for a rear flat and missed a corner, ditched it. sat upside down for an hour before he got someone to right him, and then it didn't want to start. lost all brake fluid too. fun times :-/
« Reply #117 on: May 04, 2015, 09:38:53 AM »
he must have started much earlier than us.  i only saw him righted, they looked out and about of the car off to the side and ok.
« Reply #118 on: May 05, 2015, 09:35:33 AM »
shocks came in for this unit!
« Reply #119 on: May 05, 2015, 01:00:52 PM »
Nice
