exhaust installed today, no issues. had to weld on a new turbo flange, cut one of the pipes shorter for the muffler i added, and added a hanger in the rear. everything fit fit and lined up.
Brother in law reported many problems for his 3/4 ton auto. could not get down pipe in with out removing trans cross member so he had to cut it in half. also said not fit over axle at all or line up,he side dumped before rear axle. not sure why he had so many problems.
noticed EGR block off plate is leaking coolant again same place so i guess ill fix that first before throwing more hoses at it that dont seem to be leaking.
