Author Topic: Brandy new 4500 Cummins  (Read 250697 times)
Re: Brandy new 4500 Cummins
« Reply #600 on: August 16, 2025, 05:53:34 PM »
first time i have ever worn out a new to me key fob rubber button plate.  amazon brought a pair of new housings for 15$ and i just stole the rubber part keeping the OEM plastics with screw.
funny.
« Reply #601 on: August 19, 2025, 04:18:05 PM »
changed upper rad hose / Y, topped coolant off.
probably hawg trailer around tomorrow to grab fuel to warm it up and check level before hauling this weekend.
« Reply #602 on: August 20, 2025, 02:40:56 PM »
hawged to Henrietta and back for fuel, no coolant leaks good level.
i guess at least this trip i have rolling tool box and a plated parts runner in back for the first 6hrs of the trip.
« Reply #603 on: August 20, 2025, 05:13:01 PM »
I bet she'll be good!
« Reply #604 on: August 24, 2025, 01:22:54 PM »
no issues this weekend other than ride home my EGT gage kept alarming at 1200+  and my foot and load was not agreeing.  backed off on hills just in case but even on flat ground grade or even coast it was still reading 1050+  doesnt make sence
landed home after 3-5minute cool was reading 800 still..... normally runs down to 350-400 in a few minutes at adle.
ill check tomorrow what ambient reads 60 or like 360 and just order another gage.
new in 2023 gage bah
« Reply #605 on: August 24, 2025, 03:24:21 PM »
Would be hard for a high pressure injector to stick enough to cause that for real while still holding rail pressure wouldn’t it?
« Reply #606 on: August 24, 2025, 03:55:06 PM »
no idea but i would think its smart enough to pop a million meaningless codes if that happened at least.
no smoke or lack of power
« Reply #607 on: August 25, 2025, 05:15:39 PM »
cold this AM read 70F so boo for that
ordered a new gage to replace as step 1  @ 42$
« Reply #608 on: August 27, 2025, 04:13:29 PM »
115k
another exhaust patch repair / hanger weld
oil/fuel filters/oil change
inspected boost clamps
new EGT gage should be here this afternoon.
« Reply #609 on: September 01, 2025, 11:38:40 AM »
800miles this weekend no issues to report.  new exhaust prob brought EGTs back to where remember and no 1200+ alarms anymore.
« Reply #610 on: September 26, 2025, 10:26:43 PM »
talking with my brother in law tonight at family party, his 2015 cummins needs exhaust replaced also, he ordered 2 kits for us.  see if they show up.  his is an F NY kind of guy and laughed when i mentioned i was hesitant to have it shipped to my address/name
5" muffler on sale will order tomorrow.
« Reply #611 on: October 13, 2025, 10:38:59 AM »
ordered another EGT gage mostly because of lazyness and 35$ is easier try a 3rd probe than fish new things through dash ect.
last trip coming home, watched it blink to 1300 then 1800 like an on off switch, so at least im 100$ confident its nothing to do with the truck and just stupid amazon parts being flakey.
i guess if it does it again, ill swap the cab parts with the two new ones ill have and then if that fails ill source a new setup.
because i like to do things 4 times the hard way.
« Reply #612 on: October 27, 2025, 05:06:38 PM »
Noticed a noise/skip in 4x4 when i got the truck just a hair stuck this week.
I pulled the front diff cover and all looks ok, oil was brand new looking
i dont see any front drive shaft or front axle ujoint play
Transfer case fluid was about 1/2" below fill plug, and was brown / smelled burnt ATF
changed that with the only thing documented, 70$ for 2 quarts mopar Tcase fluid for 44-47 case.
im thinking the chain is worn and stretched and slips under load?  does it in 4 low and 4 high idling with some ebrake applied at random times.
just remembered to look at your history on that chain skip noise. I overshot 2h for 4h last night moving from tank dump to the shop, and was in 4x4 on pavement with camper on. seems bad. sounded bad. I think I need to check the unknown history probably junkyard used case on my truck for similar chain wear.
« Reply #613 on: October 27, 2025, 09:18:46 PM »
mine sounded like a D30 stripping teeth off a ring gear or the noise a steel cable winch makes skipping layers under load
no sign of wear on sprockets/gears when looked at.  i couldn't really decide from the fill or drain plug if it felt loose prior to disassembly.
new chain def fixed it, no noise ever since including 4low with trailer on pavement with tire chirping loads / tight maneuvers
never could find a fluid advertised as correct other than dealer fluid.
bummer
« Reply #614 on: October 27, 2025, 09:39:41 PM »
low coolant light on way down.  added coolant
low coolant light on way back home.  added coolant.
dipsticks normal.  looking like there are some 1/2" steam lines along pass fender with various plastic tees and clamps.  reservoir top seam also noted coolant wet.
no active leaks found hot running.  leak must be very slow or pressure/load based.
no repeated EGT weirdness.  new EGT probe / harness / gage sitting in box in dash pocket.
