Author Topic: Brandy new 4500 Cummins  (Read 251225 times)
Re: Brandy new 4500 Cummins
« Reply #405 on: October 26, 2017, 12:14:33 PM »
Shit video but you get an idea
https://youtu.be/yN82utCPGgY
« Reply #406 on: October 26, 2017, 12:15:26 PM »
you've got something bigger than stock in your truck, right? as I recall the sweet spot for the HX35 is around 31-33psi, more than that and a lot of heat is the result. my wastegate kept mine to 33-34 on my 12v and it ran real nice [until it didn't]
« Reply #407 on: October 26, 2017, 12:26:06 PM »
I'm still running the stock, original tired HX35. Yes, ~30 psi of boost is about max. Anything more than that it get toasty. Waste gate not working (stuck closed).
« Reply #408 on: November 16, 2017, 08:58:59 AM »
today is the day! dropped off the RAM last night to avon Dodge.
taking bets on the bS they feed back to me!
my clear customer complaints:
1) NYS inspection: will not set more than 8/10 emission monitors in 2500miles with no CEL, currently only has historic pending Regen freq code, no CEL.
2) exhaust manifold/gasket leak causing squealing/hissing and lack of boost, lack of exhaust brake function
i bet i get back:
will not pass inspection, monitors not set- need to drive more
truck fine no boost codes, that noise is normal
sadly i forgot i cleared the 7 codes it had in Denver and drove home with no tuner and no brake.  couldnt get any codes to set
it had in Denver:
P203F
P0234
P20E8
P20EE
bah
« Reply #409 on: November 16, 2017, 11:03:31 AM »
dealer call 1
asked if i want regular or HD inspection, says it will pass.  (no sticker from new glass, valid question- but i bet they didn't plug in yet to find out it wont pass- morons)
expressed concern about exhaust leak noises again.
no parts avail for water pump recall that apparently can cause under hood fire lol
« Reply #410 on: November 16, 2017, 04:13:33 PM »
WOW
passed inspection
getting a new turbo and related gaskets under warranty NOV 27.
Internal non serviceable components blown.
« Reply #411 on: November 16, 2017, 04:21:23 PM »
you shouldn't need to have emissions monitors set to pass when >10,000#
my truck won't pass a plug in because it doesn't run monitors. I can only get a sticker because I'm emissions exempt. That requires a manual override of the inspection computer because my VIN doesn't show the correct weight class. Cab & Chassis problems. Bet your inspection shop was making the same mistake.
« Reply #412 on: November 16, 2017, 04:48:04 PM »
my truck registered as RAM suburban, passenger plate.  no GVWR on registration.
what does your title say for GVW? thats what the DMV inspection system should reference?
but cant you get an inspection without a plate or registration so how could it not just be by whats on the door? hmmm
« Reply #413 on: November 16, 2017, 04:56:47 PM »
Oh, that may goof it up. you'd mentioned that, and I forgot. I think we've had this WHOLE conversation before. Except for that last part. That's a good point. I've always shown registration, not sure if that's required. I believe that new things I've picked up for out of state destinations that wear only a NY transit temp tag have had inspection stickers on them.
« Reply #414 on: November 16, 2017, 05:01:19 PM »
well think of like salvage inspection, or if you let your registration lapse or expire, DMV requires a valid inspection before issuing registration.....
wnyjpgy
« Reply #415 on: November 17, 2017, 07:40:41 AM »
Just a side note, you can get a vehicle inspected without a registration. I have to do it with all of the wrecked cars I buy.
On the nys computer one of the first questions is, if the vehicle is registered.  If not, you can get it inspected off of the VIN alone.
It works the same way if they can't scan the registration on your window.
In your case Mike, that would be probably the best, since it would just come up diesel truck and not have to get plugged in regardless of what it's registered as.
« Reply #416 on: November 17, 2017, 08:10:25 AM »
I still don't understand the plug in vs not plug in issue.
In my experiences all my 3/4 ton trucks never had to be plugged in. Including the 2 gas trucks that had passenger plates (no GVW on reg) that "weighed" 6000.
« Reply #417 on: November 17, 2017, 09:17:00 AM »
you paid 11 not 21$?
door jam GVW over 8500?
who knows, its a hopeless system run by oil change monkeys what could possibly go wrong
« Reply #418 on: November 17, 2017, 11:11:24 AM »
oil change monkeys who have like 4 people in Albany they get to wait to talk to when things don't work right.
« Reply #419 on: November 26, 2017, 09:04:21 PM »
this unit dropped tonight at GVD for turbo replacement
