Author Topic: Brandy new 4500 Cummins  (Read 251225 times)
Re: Brandy new 4500 Cummins
« Reply #435 on: November 30, 2017, 11:39:53 AM »
that even makes 4.88 look quite tolerable, that's a huge OD.
« Reply #436 on: November 30, 2017, 12:03:23 PM »
right?  and the RAM MAX tow seems like its a good option, and i wouldnt be out of my weight class for warranty issues
cant see how RAM says 17k vs 29k trailer from a gear change and trans flash.  wonder if its bigger coolers / ect
but does that mean it gets 4mpg?  lol
« Reply #437 on: November 30, 2017, 12:36:14 PM »
it did say something about additional cooling package for Max Tow.
the tow ratings are all about 26k vs over.
« Reply #438 on: November 30, 2017, 02:06:40 PM »
IMHO the cooling system isn’t a huge limiting factor. G56’s gears can’t handle the load as well as autos can like the Aisin.
« Reply #439 on: November 30, 2017, 02:11:40 PM »
it's in the cushion of the torque convertor and the tight integration between modern automatics and the engine ECU as far as torque management.
« Reply #440 on: November 30, 2017, 02:11:52 PM »
It would’ve be nice if they do offer one of 4.10/4.30/4.44 ratios in the max tow package for better empty/light load highway cruising mpg. Tow heavy in 5th instead of 6th.
« Reply #441 on: November 30, 2017, 02:26:10 PM »
Valid point on the ecu on auto trans via reduce power output and release the TCC for split of a second when shifting. It’s actually mostly to avoid harshness
I kinda disagree on ‘cushion’, torque converter locks and no fluid-coupling in 2-6th gears.
« Last Edit: November 30, 2017, 02:27:43 PM by TrailTamer »
« Reply #442 on: November 30, 2017, 02:30:02 PM »
TC locked shifting? I'm not aisin-familiar but that's a huge surprise if so. It's at the point of engagement that it matters.
« Reply #443 on: November 30, 2017, 02:39:55 PM »
so am i dumb in thinking ill have same or better milage with lower RPMs and better power with 100ftlbs of torgue and a smart auto?
I am thinking a 4.88 auto truck is going to be an improvement, maybe if its more than enough power change, swap to 245 tires as a back up since my trailer needs new 225s anyway?
« Reply #444 on: November 30, 2017, 02:40:26 PM »
that seems the best way to get max tow package and taller over all gearing
« Reply #445 on: November 30, 2017, 04:27:11 PM »
seems like a thing?
« Reply #446 on: November 30, 2017, 04:51:37 PM »
dealer of course moron when i asked, what tune or what mechanical change is the actual MAX TOW package upgrade.
« Reply #447 on: December 04, 2017, 03:50:33 PM »
apparently when you put a Chrysler employee discount code on the table your trade decreases 4000$
crooks!
« Reply #448 on: December 05, 2017, 09:52:25 AM »
pioneer guys are still a joke
looks a door tag, looks at mileage on dash, walks around truck once at a brisk pace, goes in and looks on phone for 60 seconds and cant find any for sale.
wasted trip ha
« Reply #449 on: December 05, 2017, 01:52:46 PM »
gave car max a shot since all the reviews online were good.
Had a nice chat with a woman, too bad she wasn't single and 10 years younger.  About the most i have talked to someone in years
called before to check if they would even appraise it
too bad they were $15k shy on the number needed.
