Author Topic: Brandy new 4500 Cummins  (Read 51909 times)
Re: Brandy new 4500 Cummins
« Reply #375 on: May 08, 2017, 10:27:26 PM »
i have tried a few after similar forum chatter.  im betting my system is just fucked from running overloaded GVW on a tune.
i have tried bulk fill, walmart, or Fleet pride with same result.  i refuse to run mopar at the 10X cost.  i also use about 3X more than the brotow rigs on most forums with 2500s and dubs.   I have a DEF test kit that i carry in the truck, i have never tested my tank out of spec.
« Reply #376 on: May 09, 2017, 07:05:14 AM »
want a 55 gal drum of blue... can drop at shop ;)
« Reply #377 on: May 09, 2017, 08:25:07 AM »
what codes you're seeing?
orange anchor
« Reply #378 on: May 09, 2017, 08:28:31 AM »
Here’s what we have on the Peak DEF…
(80) 2.5 gallon jugs/skid
$11.29/jug
$903.20/skid
Smike this is what I have bought for my yard trucks.
How is this pricing?
« Reply #379 on: May 09, 2017, 09:13:55 AM »
bulk fill at truck stops is usually 2.50-3.00/ gallon
usually at walmart or Regional International i pay 7-9$ for a 2.5gallon jug out the door.
Peak i think is one of the higher end fluids and
if your buying skids at 4.50/gallon i think you could do better with drums if your usage is enough to over come shelf life and operator pumping issues.
I drum wouldnt help me as my usage is low and half my usage is on the road...
« Reply #380 on: July 31, 2017, 12:33:37 AM »
about to hit 50K
this morning i forgot there was a 48' trailer behind me with the cruse set.  Running good.  CEL stays on for emissions bs haha
need to decided if the front steers are gona get changed before October or trade it in :)
« Reply #381 on: July 31, 2017, 08:43:22 AM »
What you're going to trade it in on? Another Ram 4500/5500 but with Aisin auto trans?
« Last Edit: July 31, 2017, 09:55:52 AM by TrailTamer »
« Reply #382 on: July 31, 2017, 09:43:00 AM »
not sure.  i could just tow with the 49 for a bit :)  hahaha
ya id get a longer flat bed and 5500 with auto
« Reply #383 on: September 18, 2017, 05:31:00 PM »
broke 50K on this unit this weekend
getting a new windshield Wednesday- first time in my 16 years of driving i will be using insurance on a vehicle (full glass)
should be fun to watch how they do it with the new security cams on the job!
hopfully they do not destroy my truck
« Reply #384 on: September 20, 2017, 10:15:30 PM »
new glass installed.  cams show took guy about 40 minutes to do.
glass says mopar on it and looks factory.  insurance billed 408$, fully covered.
« Reply #385 on: September 22, 2017, 06:40:40 PM »
Do you have auto dim headlights or pressure sending wipers?
That’s the real reason for factory glass...
« Reply #386 on: September 22, 2017, 10:22:44 PM »
They actually removed all that annoying shit from the rams that Cherokees have a few years back
« Reply #387 on: September 26, 2017, 03:42:01 PM »
cant see anything different with new glass while driving.
inspection woes.  i guess ill try to see where it is after a buffalo drive.  if it doesn't set them by then ill give up caring about it.
looks like i need to put the tuner back in so i can watch it when its reg'ing and make sure it finishes.  looks like it takes 3 re gen cycles to make most of them set.
« Reply #388 on: September 26, 2017, 04:01:41 PM »
lol what kind of glass did you expect?
« Reply #389 on: September 26, 2017, 04:30:10 PM »
shit chineese glass everyone complains about, in cab mounted mirror, and associated trim parts mounted by a 15$/hr tech
wasnt happy to see under hood trim pieces being ripped off and thrown to the ground on the security cam
