Author Topic: Brandy new 4500 Cummins  (Read 251113 times)
Re: Brandy new 4500 Cummins
« Reply #360 on: November 02, 2016, 01:42:29 PM »
averaging 7.6 mpg with PA trips
put tuner back in yesterday.
« Reply #361 on: November 02, 2016, 02:02:22 PM »
ouch
« Reply #362 on: November 26, 2016, 06:29:19 PM »
dead today, confirmed batterys nuked
installed new batteries
« Reply #363 on: January 16, 2017, 10:13:32 PM »
driver side has more "click" than passenger side but both noticeable upon wheel hump when on a jack.
cant identify if its unit bearing or ball joints.  upper ball joint suspected most but its tough to tell.
probably rotate fronts and run them another 5-10K
« Reply #364 on: January 17, 2017, 05:12:28 PM »
how many miles on it now? same tires when new?
« Reply #365 on: January 17, 2017, 06:53:02 PM »
40K on truck, original continental HSRs on it.  i noticed some uneven edge wear on the driver side during the 30K oil change.  click in both wheels when jacked up, and both sides 4x4 universals had play
rears are about 50% tread even wear.  should be good for service to 75K if i keep the truck that long.
« Reply #366 on: January 22, 2017, 08:10:10 PM »
front steers rotated
rear diff fluid changed
front TREs lubed
fluids checked
brakes inspected, 1/2"+ on all pads and rotors look good.
« Reply #367 on: May 01, 2017, 09:39:29 AM »
found this deal on ebay going to try.
dealer gets 65$ for the water separator usually.
« Reply #368 on: May 01, 2017, 09:55:16 AM »
missed the linkey.
I just used up my filter stock, time to re-up. I've been doing 7500 on oil and planned to do 15000 on fuel - but my fuel filters looked PERFECT. Not a drop of water and barely any sediment in the water bowl. I think I will significantly up that, and maybe change based on filter canister rust if not milage. They were a little crusty.
I'm running FS1242 water filter and FF5320 2 micron.
Engine mounted Mopar combo filter (FS43258) is still present and I plan to completely ignore it.
EDIT: mixed up numbers
« Last Edit: May 01, 2017, 11:17:13 AM by mr.mindless »
« Reply #369 on: May 01, 2017, 10:13:38 AM »
« Reply #370 on: May 01, 2017, 10:15:41 AM »
white box would have been 90$ for the chassis filter and 39$ for the under hood, 14$ for oil if i was impatient.   its getting oil done this week, and if the filters come thursday possibly fuel before i leave this weekend.
« Reply #371 on: May 01, 2017, 02:22:51 PM »
I just priced out my replacements on ebay vs puredieselpower - I'll be going with the latter for certain.
Single source, same or better prices.
I checked your fuel filter though, and same deal. $70-$90 for the two stange on frame filter.
No way I'd keep that around if I were going to keep the truck long term. Same or better filtration costs me $28 after a one-time cost around $150 to get the dual spin-on mount.
« Reply #372 on: May 01, 2017, 04:12:31 PM »
i dont plan to keep the truck for more than 2 or 3 more oil changes but we will see.
« Reply #373 on: May 03, 2017, 08:00:57 PM »
45,383 mile service:
air filter
under hood fuel filter
chassis fuel filter / water separator
oil and oil filter change
tie rod lube
codes cleared
torn mud flap at mint400 shortened and reinstalled
« Reply #374 on: May 08, 2017, 06:04:54 PM »
have you been using the same brand of def since you bought that truck, some chatter on forums say that cel you get maybe related to low quality def and picky systems
