Author Topic: 571  (Read 264525 times)
Re: 571
« Reply #735 on: March 27, 2016, 10:12:39 PM »
Lost a day to moving and cleanup yesterday. Lost half a day to family today. Fail.
Drew myself a picture and measured things after utter failure on frontend alignment today. I think I know what I need to do now. I hope.
Going to take some comp time this week and hopefully get frontend lowered and swaybar done.
Re: 571
« Reply #736 on: March 28, 2016, 12:03:36 PM »
Klein closed. No signage up, assuming good Friday.
Motherfucker.
This one got me too.
Re: 571
« Reply #737 on: March 29, 2016, 12:02:01 PM »
Goatbuilt brackets and 185cc orbital arrived yesterday.
It was cold and shitty and I finished my taxes.
I also made a sketch and did some measurement on it because I don't know CAD, and I think I figured out what adjustments I need to make to the front links to get the axle where it belongs. Shit breaks my head and I just can't "figure" it. Very frustrating.
Re: 571
« Reply #738 on: March 29, 2016, 12:48:47 PM »
link adjustment is an advanced mental exercise.
once you force your self to realize you can adjust 1 link to move the axle 3 different ways, or you can adjust 3 links to move the axle one way- your almost there.
ill admit, its easier to just put it on the lift and pick one to start to twist and watch what happens haha
Re: 571
« Reply #739 on: March 29, 2016, 12:55:23 PM »
twistable links help too.
I was honestly thinking of removing all links and tweaking the axle to exact position and then adjusting the links to mate it where it is placed.
I might still do that: I'll probably end up running these links for another year; the lowers probably deserve to be flipped; I know I need to do at least 1-2 if not all 4 bushings.
fuck no lift. fuck no heat. fuck needs for open garage doors.
taking time off tomorrow morning, and thursday.
Re: 571
« Reply #740 on: March 29, 2016, 01:20:54 PM »
that guy should be fired!  hhaha forgot about that.  bummer.
id pull 3 of them, set the 3rd to middle travel,place axle then go from there and re assemble.
Re: 571
« Reply #741 on: March 29, 2016, 01:24:41 PM »
and honestly, dont get tied up on getting the axle centered and straight- we arent road racing.  functional and biased for clearances to not break things is much more important.
with a much tighter orbital whats your steering cooler situation again?
Re: 571
« Reply #742 on: March 29, 2016, 01:30:59 PM »
well right now it's shifted to the wrong side for clearances, so double fail :)
I have 3 coolers up front now. one dumb tube & fin, one good tube & fin, one good stacked plate.
I *think* the steering is currently on the dumb tube & fin. I could swap it with the good tube & fin seeing as the trans never gets even close to hot? I will also be looking for a place to mount the spin-on system filter I harvested from the Dakota like you have now. that'll add some capacity - and it will go ahead of the cooler to keep pressures in the cooler as low as possible.
All front coolers need to shuffle around a bit with the increased bump. A radiator hose needs to move too, that's sad. I need to get rid of some coolant. Big box stores take that for recycling?
Re: 571
« Reply #743 on: March 29, 2016, 01:46:16 PM »
all my coolant used coolant gets dumped directly into the shovels radiator or used as weed killer around the shop
your too nice!
reminds me, my car currently has no steering cooler plumbed in meh.
Re: 571
« Reply #744 on: March 29, 2016, 01:52:33 PM »
anybody that sells by law has to take..
if they tell you otherwise they are full of shit
Re: 571
« Reply #745 on: March 29, 2016, 02:04:53 PM »
that's what I thought.
I have too many amnimals about to dump shit. also have streams and swamps right nearby so I'm even above digging a hole for it.
Re: 571
« Reply #746 on: April 03, 2016, 10:01:53 PM »
Fun fact: front bump cans are an inch off from one another side to side.
I need to add half an inch of wheelbase to clear the truss with the pinch bolts. getting closer to progress. Race will be a squeeze. Again. If I even get shocks in time.
Re: 571
« Reply #747 on: April 04, 2016, 12:05:43 AM »
everything worked fine for me for 3 years :)
Re: 571
« Reply #748 on: April 11, 2016, 11:32:58 PM »
New 3 layer Spearco suit is really nice
Re: 571
« Reply #749 on: April 12, 2016, 08:51:12 AM »
dont rip out the back getting in and out of the car.... i went through 2 cheap suits, and im on my second sparco jadeII, finally just bought a 3X thats way too big but doesnt rip when i crawl out of the car....
