Re: 571
« Reply #675 on: March 08, 2016, 03:40:21 PM »
5/8" heims are used for sway bars and woble stoppers
7/8" heims are used for all steering and track bars
1.25" used for all links
common on 572 and 928
Re: 571
« Reply #676 on: March 08, 2016, 04:01:47 PM »
Same here...
Re: 571
« Reply #677 on: March 08, 2016, 04:41:18 PM »
Even our LJ has 7/8 steering heims.
Re: 571
« Reply #678 on: March 08, 2016, 05:26:57 PM »
5/8 it is, then!
1" link material, then? 1.125"?
Re: 571
« Reply #679 on: March 08, 2016, 10:33:40 PM »
How much twist are you guys putting on those stock car bars? I’m looking at asking 40* of it at full flex with a 21” arm. That strikes me as a bit much.
Re: 571
« Reply #680 on: March 08, 2016, 11:05:32 PM »
axle or link mounting your links?  40 sounds about max
Re: 571
« Reply #681 on: March 08, 2016, 11:12:28 PM »
There are a TON of different spline diameters it seems. 7/8, 1, 1.25, 1.5, 2... What did you guys pick? I guess I’m liking 1.25?
I’d really like a bar around 31-33” long but it looks like 37.5 is going to be the most available length.
Re: 571
« Reply #682 on: March 08, 2016, 11:13:42 PM »
Axle mounted. Round aluminum links, no funny business.
Might be able to find a few more inches for link length.
Re: 571
« Reply #683 on: March 08, 2016, 11:17:41 PM »
http://www.ebay.com/itm/160255304258?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
we have every size from 3/4 to 1 3/8 bar diameters on the shelf  1 1/4 spline dia
Re: 571
« Reply #684 on: March 08, 2016, 11:21:30 PM »
search schroeder sway bar arms on ebay
i dont see the 1.25 ones we use.
Re: 571
« Reply #685 on: March 09, 2016, 12:17:33 AM »
There are a few 1.25” sets. I’ll probably mod the longest steel ones I can get. Will look at clearance and layout a bit before I order...
Probably doing the bumps on the arms too pending results of watching the rear flex and thinking on angles. Looking forward to the “I told you so” after that doesn’t work out.
Re: 571
« Reply #686 on: March 09, 2016, 07:26:44 AM »
the way i extended my arms is pretty strong and light, not pretty.
i remember looking at bump location more than once on that car and there isnt an easy solution.  might try googling twisted customs chassis to see.   there are a few out there similar shorter cars
Re: 571
« Reply #687 on: March 09, 2016, 10:33:39 AM »
did you do schroeder 49sp or SCP 48sp?
found some good 48sp arms, looking through all the bars now.
Re: 571
« Reply #688 on: March 09, 2016, 02:30:33 PM »
i believe ours are all 49 spline.  i was gona mention to be carful of that.
would be nice to have the same as our two cars like i said we have at least 5 bars on the shelf.  i also have a spare set of new 4130 arms
Re: 571
« Reply #689 on: March 09, 2016, 03:13:50 PM »
yeah I'm trying to stay consistent on things where it makes sense.
perfect pair of 48sp for $82 http://www.ebay.com/itm/NEW-SCP-1-1-4-steel-sway-bar-arms-48-spl-l-30-degree-
Looking at $70-80 ea for retail price on new 49sp. interested in parting with your spares if they are straight or 15Ëš until more 49s come up on fleabay?
