Author Topic: hannah's build thread  (Read 35917 times)
Re: hannah's build thread
« Reply #150 on: October 26, 2015, 03:05:17 PM »
defiantly a sweet window!
« Reply #151 on: October 26, 2015, 04:34:20 PM »
Nice going Hanna!
Hannah
  • Full Member
« Reply #152 on: October 31, 2015, 03:07:36 PM »
Fixed the rear window, good thing there are spare parts all over the garage!
Hannah
  • Full Member
« Reply #153 on: November 25, 2015, 07:55:55 PM »
Thanks Cora for the pictures and feature in the latest JP Freek Adventure magazine, pages 56 and 68-73! Women's Wheeling day was a blast! http://currentissue.jpfreek.com/publication/index.php?m=16482&l=1#%7B%22issue_id%22:282532,%22page%22:1%7D
« Reply #154 on: November 25, 2015, 08:18:21 PM »
Great write-up and pics!
Hannah
  • Full Member
« Reply #155 on: April 23, 2016, 11:35:24 PM »
Decided last minute last night that with a free day today we'd finally get started on my front bumper build. Got some steel this morning and got pretty far with it today. Making brackets wasn't too bad, and I got to practice my welding skills which got better by the end. Tomorrow we will weld in the side pieces and start grinding them all smooth.
« Last Edit: April 24, 2016, 09:46:39 AM by Hannah »
Hannah
  • Full Member
« Reply #156 on: April 25, 2016, 09:13:14 AM »
Yesterday I got the side pieces of the bumper tacked on and welded caps in the ends. Trimmed the recovery points. Smoothed out all the welds so far. Then I plasma cut some pieces that will double up the recovery point, and wedges for underneath strength. First time Harry's let me plasma cut, and it's the greatest thing! I never want to use cut off wheels again!
CJ
« Reply #157 on: April 25, 2016, 09:33:38 AM »
Looks awesome Hannah!!!
Plasma cutters are the best  8)
Hannah
  • Full Member
« Reply #158 on: April 25, 2016, 09:38:20 AM »
Thanks Cora! I really like how it's coming out so far. Simple and keeps the front still looking clean and untouched. Harry thinks I'm ready for the welds that won't be ground down so hopefully that will go ok next!  Plasma is the best!! I told Harry I'll plasma all his stuff for him
« Reply #159 on: April 25, 2016, 10:16:28 AM »
One of my favorite sayings:
Welding Grinding god!
Hannah
  • Full Member
« Reply #160 on: May 30, 2016, 10:30:37 PM »
Coming along! Welded up the bumper today. I think I'm improving :) Just need to do some grinding, painting, and cut holes in the tow points.
« Reply #161 on: May 31, 2016, 09:43:24 AM »
Nice welds!
« Reply #162 on: June 14, 2016, 12:05:56 PM »
So, 3 weeks from motor order date and my 1.5 week lead time motor has not shipped. Motor is built aside from cam. Two, yes two cams have shown up chipped or broken. So driving this sweet ride 270 miles to RC is looking like the plan if we want to wheel July 4th weekend.
Coming up with a prep checklist
-Accessory squeak, guessing either alt or idler
-Steering box leaked from column input when let droop during bumper removal, self healed. ?? investigate
-Dim headlights, investigate. Maybe add some aux lighting
-Starts hard, consider ignition tune up
-Perform Dan's driveway alignment method using chalk or something, he swears by it but I need to be educated
-Gas leaks from top of tank when topped off, safety issue worth dealing with before trip?
-Check ball joints, wheel bearings, tie rod ends, wheel spacers
-Check and top all fluids
-Check and tighten all suspension connections
-Check brakes
Battery, belt, radiator are all new, cooled well on last highway trip. Runs good, has been reliable since we've had it, though has probably only had 3000 miles put on it.
I forgot about the gas leak until I started making this list, bah. Drips from corner of skid when topped all the way off, appears to be coming from the top of the tank. I suspect there is some slight rotting up there and the skidplate pushed the tank up into the floor a bit.
Reasonable amount to get done in two weeks I think, and all things that need to be checked and dealt with anyway. But leaves the potential for several hundred dollars to be spent on a budget wheeler inside a short period of time.
« Reply #163 on: June 14, 2016, 03:51:19 PM »
so set the tow with a tape measure and fill tank to 3/4 is what i read
« Reply #164 on: June 14, 2016, 03:55:53 PM »
*toe
ditto!
