Author Topic: hannah's build thread  (Read 35915 times)
Re: hannah's build thread
« Reply #135 on: October 15, 2015, 05:13:51 PM »
Reattempting Aussie 8.25 install with new cross pin and thicker thrust washers. That better do it!
CJ
« Reply #136 on: October 15, 2015, 07:14:42 PM »
what was the center gap before?
« Reply #137 on: October 15, 2015, 07:18:26 PM »
.173
CJ
« Reply #138 on: October 15, 2015, 07:25:56 PM »
That's OK. You can go up to .180 in a gray area... but with her tire size I wouldn't be worried at .173.
« Reply #139 on: October 15, 2015, 07:29:42 PM »
Was popping on road before and took it out. So got new crosspin and an assortment of thrust washers of various thicknesses to try to tighten it up a little. Previous owner experienced popping and would unlock sometimes on the trail. Dan and I inspected and teeth are a little worn on one side but doesn't look like it should be enough to cause an issue.
CJ
« Reply #140 on: October 15, 2015, 08:46:38 PM »
Cross pin is a very good place to start. Slipping can sometimes be caused by a bent axle shaft or tube. Take a look when you have some time. You can send me pics of the teeth and I will let you know what I think. If you are still having issues, I have a C8.25 scratch and dent she can have. Some of our older 8.25 Australian units had a bad couple batches that were replaced under a warranty recall. Do you know if her locker says 'made in USA?'
« Reply #141 on: October 15, 2015, 08:50:55 PM »
This locker is at least a couple years old so I'm guessing it is an Australian unit. I will get some pictures.
« Reply #142 on: October 16, 2015, 08:26:52 AM »
I would demand stickers for all this hassle from Customer Service.
What a pain!
Hannah
  • Full Member
« Reply #143 on: October 16, 2015, 08:30:22 AM »
Busy weekend coming up!
Hannah
  • Full Member
« Reply #144 on: October 17, 2015, 06:46:36 PM »
Got front and rear Aussies installed today, both seem to be working. Thanks Cora for hooking a girl up! Also got a new Solid cover on in the front, thanks to Harry :) Got my rocker panels and stiffeners painted too. All that's left is to put the t-case skid back on tomorrow, needs to be straightened out a bit first.  Almost ready for Womens's Wheeling at Rausch next weekend!!
« Reply #145 on: October 17, 2015, 07:44:12 PM »
Time for some wheeling!
jacel861
  • Full Member
« Reply #146 on: October 17, 2015, 09:04:38 PM »
Looking good!
« Reply #147 on: October 17, 2015, 11:06:34 PM »
Awesome!!!
Hannah
  • Full Member
« Reply #148 on: October 25, 2015, 08:15:50 PM »
Oops!
« Reply #149 on: October 25, 2015, 10:51:42 PM »
How sweet is your rear window?
