Author Topic: hannah's build thread  (Read 36123 times)
Re: hannah's build thread
« Reply #120 on: May 02, 2015, 08:19:37 PM »
Nice
« Reply #121 on: May 18, 2015, 10:33:00 PM »
SYE done. Ready for Rausch this weekend!
Hannah
  • Full Member
« Reply #122 on: May 18, 2015, 10:35:53 PM »
Thanks Harr!! Can't wait :-D
« Reply #123 on: May 19, 2015, 08:13:01 AM »
Bling
« Reply #124 on: May 19, 2015, 09:25:45 AM »
Is that a hack & tap or something similar?  Looks different that what I'm used to seeing...
« Reply #125 on: May 19, 2015, 09:36:57 AM »
With the bolt holding the yoke on, I'm pretty certain it's a hack & tap. And now I know what that means! :)
Hannah
  • Full Member
« Reply #126 on: May 19, 2015, 09:38:48 AM »
It's a hack & tap, the stock driveshaft was bottoming out so we got these parts and Harry's picking up a front drive shaft to stick in there. Headed to Rausch this weekend to see how the new tires do!
« Reply #127 on: May 19, 2015, 09:51:41 AM »
 8)
« Reply #128 on: May 19, 2015, 10:45:43 AM »
Since we did the lift and 8.25 swap at the same time, the longer D35 driveshaft was a good fit, maybe a little on the long side. Now that the rear has settled, it's definitely too long.
Hack'n'tap is the only option for a 242. Older cases have the oil seal around the slip yoke. Had to also get the replacement seal housing for hers which is that red piece.
Hannah
  • Full Member
« Reply #129 on: September 15, 2015, 11:39:02 PM »
Been awhile, Jeep needs some much needed love! Since I've been busy moving to NY recently, but really want to wheel this fall for the women's day wheeling event at Rausch in October, Harry's helping me out. Tonight he replaced the stock control arms with some beefier arms we got used. Dented the arms pretty bad last time wheeling so it was good to finally do this. My next few weekend plans are to help make rocker panels and weld on stiffeners to the unibody before it gets worse. Since last wheeling trip my door is a little off and rain leaks in just a little bit.  :o Going to try the locker in the rear with a new cross pin this time. Crossing our fingers this will fix it's issues!
« Reply #130 on: September 16, 2015, 09:36:38 AM »
Jeepie will look great on the streets of Brooklyn!! :)
If you happen to need trash chute or boiler repair work down there I’ve got a guy for that.
Also, L&B’s Pizza. Upside down and AMAZING.
Hannah
  • Full Member
« Reply #131 on: October 05, 2015, 01:32:03 AM »
Productive weekend! First, took the t-case skid plate and cross member off, used the grinder and got all the black coating off the unibody rails, and got the stiffeners welded in. Cut out end caps and welded them to the box tube ends, then ground them smooth. I finally got to weld for the first time, I was super excited  :D Cut out the old rockers and Harry and I fit the new ones in and he tacked them all. There's a spot we had to cut out that was crushed and rusty so we'll have to fill it in later. After I left Harry's tonight, he welded more of the rocker panels, until he ran out of oxygen. While I'm at work this week he'll prime the stiffeners and I got some flat metallic charcoal spray paint for the rocker panels to match the flares and door panels.  Next up... lockers  ;D
« Last Edit: October 05, 2015, 01:35:15 AM by Hannah »
Hannah
  • Full Member
« Reply #132 on: October 05, 2015, 01:36:11 AM »
more pictures
« Reply #133 on: October 05, 2015, 07:57:25 AM »
Looking Great Hanna!
Awesome to see you with a helmet on!  Those sliders look nice!
CJ
« Reply #134 on: October 05, 2015, 09:25:33 AM »
Wohoo! Jeepie is getting beefy!
Can't wait to go wheeling together!!
