Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 103901 times)
« Reply #645 on: July 31, 2014, 09:21:29 AM »
Quadratic has quick shipping.
« Reply #646 on: August 01, 2014, 08:15:54 PM »
Looks like the same area that was "wet" just decided to be "drippy". Seam area in reservoir seems to be the culprit. Likely thinner fluid in hot climate made the inevitable happen sooner. Oh well.
Do I need one from an i4 or are these interchangeable in TJs?
« Reply #647 on: August 01, 2014, 08:24:56 PM »
I4 reservoirs are unique to themselves.  :(
« Reply #648 on: October 05, 2014, 10:16:38 PM »
Starter isn't starting. Have plenty of bat. Relays for fuel  and starter click. Just doesn't spin the motor. Bypassing the solenoid spins the starter but doesn't actually turn the motor over. Is it worth replacing just the solenoid or just do the whole starter assembly?
« Reply #649 on: October 05, 2014, 10:24:27 PM »
So the starter spins but not engaging?
« Reply #650 on: October 05, 2014, 10:26:51 PM »
Only when shorted. Key does nothing.
« Reply #651 on: October 05, 2014, 10:29:05 PM »
Short from the big lug on the starter (always live) to the little lug (trigger wire from ignition)
If it turns the motor over something else is going on. If it doesn't, replace the starter and you're done.
« Reply #652 on: October 20, 2014, 05:10:17 PM »
What's the magic tool to get the starter off? No idea what those heads are. Nothing in my kit fits.
« Reply #654 on: October 20, 2014, 07:20:04 PM »
So it looks like a 12pt 3/8" should get it? Just making sure I read that right.
Mine looks like the T55 torx socket I use for hinge removal. My chiltons manual didn't say what the bolt "should" be.
« Reply #655 on: October 20, 2014, 07:24:22 PM »
from what i read its either or of the 2
« Reply #656 on: October 20, 2014, 09:16:20 PM »
http://www.amazon.com/Lisle-26830-E-12-Torx-Socket/dp/B000P0TZ60/ref=sr_1_9?s=hi&ie=UTF8&qid=1413854146&sr=1-9&keywords=Star+Socket+E12
edit: or buy these - http://www.amazon.com/Anytime-Tools-FEMALE-E-TORX-SOCKET/dp/B000I45Y8Q/ref=sr_1_4?s=hi&ie=UTF8&qid=1413854196&sr=1-4&keywords=Star+Socket+E12
I'm not sure if you have Amazon Prime.  if you don't, its well worth looking into the Prime. As you know, the selection of stores around in this area aren't that great so I buy all the stuff on Amazon and get it 2 days later.
« Reply #657 on: October 21, 2014, 07:06:24 AM »
My wife and I both have Prime.
It's worth every penny.
Our UPS guy is like family.
« Reply #658 on: October 21, 2014, 08:02:16 AM »
i use mine, gotta love 2 day shipping
« Reply #659 on: October 21, 2014, 08:18:49 AM »
Only thing I dont like about Amazon is no Paypal, other than that I use it, Just ordered belts this morning because I left a belt at a security checkpoint somewhere...
