Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 119589 times)
« Reply #660 on: October 21, 2014, 08:46:38 AM »
I agree ryan.
But to me I feel the reviews of sellers and products are worth more than PayPal.
« Reply #661 on: October 21, 2014, 09:23:01 AM »
paypal is a necessary evil. awful folks, I can't wait for upstarts to get enough buyin to put pressure on them.
« Reply #662 on: October 21, 2014, 04:09:21 PM »
No dice on 3/8 12. Not even close. 10mm fit but only succeeded in making a mess. Looks like I'm buying tools.
« Reply #663 on: November 02, 2014, 11:44:59 AM »
bought sockets. Started on floor of shed where it is getting regular abuse.
Note to other ... morons ...
Do not remove the wiring from the starter AND remove all the bolts without finding some support for the starter. It will fall right out and onto you.
« Reply #664 on: November 15, 2014, 12:01:57 PM »
new starter in. old starter did nit spin on test so it WAS bad...
now not getting power to starter. swapped relay... no power. metered "trigger" at relay... no power on key. Fuses all look good. not going to be a happy day pretty soon....
« Reply #665 on: November 15, 2014, 03:44:20 PM »
Try shorting power over to the solenoid. Hannah's has the same issue. Pretty sure it's just a bad wire between fuse block and solenoid.
« Reply #666 on: November 15, 2014, 04:07:19 PM »
shorted at relay. With key in "on" started right up.
based on continuity and "trickery" i've got it down to something between the key and the harness. Looks like there is a common problem with the switch actuator. I'm just going to add a "push button" start via my intention to hack the dash. I was 90% of the way there so ... easy for me to complete that.
Anyone got a TJ wiring harness (connectors really) that they want to unload?
« Reply #667 on: November 16, 2014, 07:05:04 PM »
Pushbutton to bypass defective ignition done.
« Reply #668 on: March 17, 2015, 04:41:44 PM »
Driving down the road, hit brakes, pedal for to the floor. Get it stopped and find brake fluid all over driver rear. I'm starting to hate brake systems. Drums in particular.
« Reply #669 on: March 17, 2015, 05:01:25 PM »
I think you might be cursed.
« Reply #670 on: March 17, 2015, 05:04:59 PM »
Suddenly my massive purchase of dot5 doesn't seem so insane! Was planning on a complete rebuild in June to switch over.
At least I have all replacement for rear sitting and ready to go on.
« Reply #671 on: March 17, 2015, 05:22:27 PM »
stop using the brakes some much dumb dumb
« Reply #672 on: March 17, 2015, 05:23:12 PM »
Is there no disc conversion available?
« Reply #673 on: March 17, 2015, 05:33:40 PM »
Disc conversion on a Dana Turdyfive?  8.8 is the conversion!
« Reply #674 on: March 17, 2015, 05:34:12 PM »
SMike that's a great idea. I can probably roll over most of the cars here.
Yes there is a disk kit. But it will be attached to an 8.8. Not throwing that kind for $$ at a d35
