Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 103901 times)
« Reply #630 on: May 14, 2014, 08:00:30 PM »
If there's no offset of the tires your steering may be off center. Too long. Of a Drag link.
« Reply #631 on: May 15, 2014, 12:56:35 AM »
Measure axle to frame relationship.  And what sMike said.
« Reply #632 on: June 21, 2014, 11:03:06 AM »
ZJ tierod and solid cover... Not much clearance on hard driver. Passenger is a bit better.
Tips on how to get that fill plug in before I head to store for giant Allen wrench?
« Reply #633 on: June 21, 2014, 11:33:57 AM »
giant allen wrench
« Reply #634 on: June 21, 2014, 11:35:13 AM »
That's what I thought. That or a bolt with nut stacked. Hmmm
« Reply #635 on: June 21, 2014, 04:17:13 PM »
Wrench acquired. Fluid contained kind of. Test drive and locker is much quieter than before. I know my pinion seal is not much of a seal so I'm wondering if I didn't have enough fluid in the diff. On the other hand, I didn't realize how much higher the full plug is in the solid cover so I slightly over filled the diff this time.
Quieter is nice though...
« Reply #636 on: June 21, 2014, 05:54:39 PM »
Take a 3/8" bolt and lock 2 nuts on the end, use a normal 9/16 ratchet
« Reply #637 on: June 21, 2014, 05:57:13 PM »
O god, ya dont fill to plug lol.  D 30license only gets a single quart
« Reply #638 on: June 21, 2014, 05:59:52 PM »
Well that explains my scratching my head when I started the third quart.
Noted for the future. One quart.
« Reply #639 on: July 02, 2014, 10:13:51 PM »
Well, 4 days and the most "built up" jeep I've seen is a TJ rubicon on 33s. Maybe 2" lift. No mall crawlers either. Granted I'm in the "working mans" section of the area so I might just not be seeing them.
What there are an over representation if is over lifted trucks. What good is a 12" lift on a 150 running 33s? There are so many of them that it can't be an accidental "stupid move".
Oh well. Still need to find someone here to head off the pavement with...
« Reply #640 on: July 02, 2014, 11:22:42 PM »
Welcome to the south!    8) 8) 8)
They are called Brodozers.
« Reply #641 on: July 03, 2014, 03:23:36 AM »
Lol. Great name.
Some hardlinecrawlers folks may be closeish?
« Reply #642 on: July 31, 2014, 07:33:37 AM »
Bah! Catastrophic loss of steering fluid at 55mph. Haven't opened the good to investigate. Irrelevant as I can't actually find a "local" <redacted> or <redacted> to buy parts from.
Any way... Mark noticed a leak in my reservoir while we were doing repair. Could be anything though. Other than "buy a different Jeep" what should I look to upgrade while I'm pulling steering stuff apart?
« Reply #643 on: July 31, 2014, 07:43:49 AM »
Probably blew a hose.  Shouldn't be an issue finding new.  Not a usual failure point so no upgrade needed.
4 cyl reservoirs have always been problematic due to cracking.  That might do with an upgrade from PSC or something.
« Reply #644 on: July 31, 2014, 08:55:53 AM »
fill, find leak, fix / replace
