Author Topic: '02 TJ with i4 -- Mid Life Crisis  (Read 104021 times)
« Reply #615 on: May 08, 2014, 12:03:50 PM »
comes on respective to fuel level for and emissions self test it runs- hot soak, cold start, vapor present in tank....
« Reply #616 on: May 08, 2014, 12:39:41 PM »
boom
« Reply #617 on: May 08, 2014, 01:09:14 PM »
« Reply #618 on: May 08, 2014, 01:16:48 PM »
question.  answer.  boom!
« Reply #619 on: May 08, 2014, 01:27:12 PM »
depending on year, you are allowed to fail a certain amount of emission monitors.  Enough of the monitors must be set to pass plug in.  if they are not set, it doesn't necessarily cause a CEL.  My ZJ has 6 i believe.
you driving around at greater than 1/2 tank just means the jeep has not run the emissions test yet.
id suspect gross evap leak will be the code.  check hoses on canister system, gas cap, ect.
unplugging the battery hurts you here as all the monitors are reset and need to re perform the tests and self pass.
« Reply #620 on: May 08, 2014, 01:31:03 PM »
Well, on one hand I don't care. Got my shiny new inspection sticker before she CELd me. But I really dislike the sudden loss of power and rough running (remember the 2k cough post LCA? Worse now).
I'll run it to my local guy tonight and get the codes. Then decide the next step.
« Reply #621 on: May 08, 2014, 01:56:43 PM »
you got to get yourself and ELM327
« Reply #622 on: May 08, 2014, 01:58:51 PM »
Actually I need to get a raspberry pi and get the AVR to forward the codes for automatic lookup and display. But it is all packed up. Local guy is good enough for now...
« Reply #623 on: May 08, 2014, 02:05:29 PM »
You love complication huh?  lol
« Reply #624 on: May 08, 2014, 02:15:27 PM »
Why do it simple when you can make it "engineered"?
« Reply #625 on: May 08, 2014, 06:24:43 PM »
O2 high voltage -- unit 2.
This a "novice" job?
« Reply #626 on: May 08, 2014, 06:31:34 PM »
If it comes out, easy.  If it doesn't, cut and weld.
« Reply #627 on: May 14, 2014, 07:28:47 PM »
BAH!!
Front passenger wheel seemed to be "dragging" on full lock to the right. Looked under and discovered the tire is making contact with the lower control arm. Driver side has tons of clearance. Looks like adjustable track bar is next on my list.
« Reply #628 on: May 14, 2014, 07:34:48 PM »
dont turn as hard that way
« Reply #629 on: May 14, 2014, 07:37:51 PM »
Great idea. Too bad the idiots at work seem to want to challenge me to practice for Rausch using their Priuses (WTF is the plural for Prius?).
I would have expected a visible offset of the tires to the driver side ...
