Author Topic: rescuing an old friend  (Read 114613 times)
« Reply #195 on: August 14, 2012, 09:53:32 AM »
way too high :)
« Reply #196 on: August 14, 2012, 09:58:08 AM »
I guess.  Going from the stock TJ 34:1 to the Rubicon 65:1 was a real boost for me!  Not often now do I get into a spot where lower gearing is needed.  Can't imagine 100:1.
« Reply #197 on: August 14, 2012, 10:01:48 AM »
If I was in a comp crawl then I can see 100:1 but for trail riding now I'm in 3rd- 4th 4low and I'm about right pace. If I get to a good section I want to take my time I'm in 2nd first is almost to slow
« Reply #198 on: August 14, 2012, 10:10:34 AM »
what do rubi's have for first gear?  Tom was much slower than I at big dogs and I'm like 90:1.  I could use lower occasionally, especially down hill.
« Reply #199 on: August 14, 2012, 10:14:00 AM »
all what I always thought..
but I’m telling you.. I needed more slow for what I was doing..
100:1 is a lot.. but the lesser of 2 evils.. If I can’t get the gearing I desire from a Tcase I need a trans...
granny gear trucks are the only option..
Funny, because when I had to move Pauls CJ this winter in storage I forgot how much I loved a deep 1st gear.. (had one in a previous CJ)
it’s all about the overdrive at this point....
only way out there possibility is that the case isn’t 4:1....
but that would have taken some serious "Fuck you" ability by the PO of the Tcase to swap the planetary back into the Tera housing...
plus I’m fairly certain I checked it before I installed it..
« Reply #200 on: August 14, 2012, 10:18:34 AM »
NP241OR t-case = 4:1
NVG3550 trans = 4.01:1
D44 axles = 4.11:1
Must be a Jeep thing  :P
« Last Edit: August 14, 2012, 10:20:53 AM by Wingman »
« Reply #201 on: August 14, 2012, 10:21:39 AM »
65:1
AX15 is 3.83 (where im at..) 62:1
need more slow.. less go
« Reply #202 on: August 14, 2012, 10:24:12 AM »
that's really weird cause I'm 3.95, 5, 4.10, must be the 38's.  More like 75:1 I guess...
« Reply #203 on: August 14, 2012, 10:25:19 AM »
your at 80:1
I dont think tire size effects the calculation.. just the real world application..
carchameleon
« Reply #204 on: August 14, 2012, 10:26:39 AM »
i'm
6.32
2
3.55
only 44
i want lower
6.32 is pretty cool though  :-D
« Reply #205 on: August 14, 2012, 10:27:25 AM »
Put that thing on jack stands and verify your t-case gearing?
« Reply #206 on: August 14, 2012, 10:27:31 AM »
I typo'd.  3.95, 4.7, 4.10
« Reply #207 on: August 14, 2012, 10:46:43 AM »
The only thing I can see is tire size messing with things.
« Reply #208 on: August 14, 2012, 10:47:28 AM »
toms tires to 38's is huge diff lol
« Reply #209 on: August 14, 2012, 10:48:32 AM »
thats it, i'm going to 33s!
