Author Topic: rescuing an old friend  (Read 114823 times)
« Reply #180 on: August 14, 2012, 12:26:19 AM »
for you perfect, for anyone else useless as all hell.
« Reply #181 on: August 14, 2012, 08:27:32 AM »
If I hadn't picked up the Rubicon, I would have swapped in an Atlas or Stak.  Crawler gear for wreck wheeling is nearly the holy grail!
« Reply #182 on: August 14, 2012, 08:29:50 AM »
please explain
« Reply #183 on: August 14, 2012, 08:48:58 AM »
expensive
bolt in
weak
you can say you have an atlas though!
« Reply #184 on: August 14, 2012, 08:52:50 AM »
you are the second person to tell me its weak...
It was suggested to me to go with a T18 and keep the 4:1 NP231...
I dont think weak is perfect for anybody.. but I will give you the other 2.. I do like turn key, easy things..
« Reply #185 on: August 14, 2012, 08:58:03 AM »
well there is a lot of speculation i don't really care to read up on pirate about-
they had oiling issues, and supposed fixed- so careful about what gen you buy.  Seems like Racers still cant make them last- which would make me be cautioned on a street rig at highway speeds.
« Reply #186 on: August 14, 2012, 09:01:35 AM »
exactly what was said to me.....
I agree... if this was a dedicated trail rig it would be another story..
but then again if it was a dedicated trail rig I wouldnt have this problem because I would have deeper axle gears...
I need to spend some time with the jeep in 4th and see if I can live without an overdrive... I have a feeling its going to be a new tranny
« Reply #187 on: August 14, 2012, 09:07:27 AM »
Swapping in a Rubicon case would be a better option.
NV4500 or SM420 would be a better choice if you are swapping transmissions.  You get a good low first and overdrive with the 4500.
« Reply #188 on: August 14, 2012, 09:12:25 AM »
what’s inherently the difference between the rubi case and a tera low unit?  same ratio right?
T18 keeps it all relatively simple.. plus I have a source..
« Reply #189 on: August 14, 2012, 09:13:37 AM »
Ratio is the same, but the Rubi case has larger internals, its a 241 not a 231.
« Reply #190 on: August 14, 2012, 09:15:17 AM »
got it.. but same mounting pattern...
so in the grand scheme of life it can be an upgrade for later while addressing a different issue now..
« Reply #191 on: August 14, 2012, 09:15:59 AM »
I think the only thing the Rubi case would give you is a slightly beefier chain and gears, it is the same ratio as you have. T18 sounds like a good way if it has lower gears then your current trans.
« Reply #192 on: August 14, 2012, 09:20:26 AM »
would jump from 63:1 to 104:1
« Reply #193 on: August 14, 2012, 09:45:10 AM »
wait...  63:1 isn't low enough for you?  :o
« Reply #194 on: August 14, 2012, 09:52:58 AM »
Thats what I thought....
but im telling you there was more that 1 time this weekend where sombody asked
"not to be a dick, but you are in 4 low"
lot of clutch slip and throttle was used where it shouldnt have been needed..
just not creepy enough...
