Author Topic: High Miler  (Read 301921 times)
Re: High Miler
« Reply #585 on: September 20, 2016, 08:57:11 AM »
bummer.  i have put 4 arb's in on street jeeps.  about a year service so far, no issues.
Re: High Miler
« Reply #586 on: September 20, 2016, 11:50:00 AM »
and I guess an AC compressor, drier, oriface tube and some oil belong on a list too. maybe I'll put that off 'till spring at this point.
We literally should combine our trucks' a/c problems to have two trucks with good A/C.
My truck's a/c is broken but in a completely opposite way. It gets WAY too cold, kinda feel like as if I open a freezer. If I let it running long enough I'll get zero air flow due to the evaporator all iced up. I need to turn the a/c off perodically to keep the ice down.
Re: High Miler
« Reply #587 on: September 20, 2016, 12:30:57 PM »
you could be overcharged?
I don't remember if there's an evap temp sensor on the 2nd gen but if there isn't I'm not sure how they are supposed to prevent that. There probably is one and it's probably failed. IDK if there could be any way to get to it without pulling and splitting the HVAC box
Re: High Miler
« Reply #588 on: September 20, 2016, 12:39:21 PM »
There's high and low pressure switches I believe because my truck have orifice tube. I think the low pressure switch (on cold side, post evaporator) is bad so it don't turn off when the pressure get too low.
and technically no, overcharge don't make a/c colder. overcharge will act similar to undercharge (cycling, mostly due to too high pressure on hot side).
I plan to literally tear down my dash down to firewall eventually.... I will need to do that to put in the dash I got from you in like 3 years ago? Major job to replace the dash so I am holding it off until I have everything I'll need to do everything else while I'm there anyhow... heater core, evaporator, some hvac door actuators (none are broke right now but might as well replace the ones that's not easily replaced when all assembled, 20 years old now and 300k, so something has to give anytime soon) and rewire most, if not, everything behind the dash and possibly new, custom cluster to get my gauges off my a pillar.... I only can do so much...
Re: High Miler
« Reply #589 on: September 20, 2016, 01:39:40 PM »
rear diff and ARB parts all ordered from justdifferentials including a listed speedie sleeve for the pinion yoke seal.
will plan to do this work the week of 10/1
Re: High Miler
« Reply #590 on: June 04, 2017, 05:24:29 AM »
Need to do rear brakes this week. Have to check the parts pile to see if I have pads. I know I have ebrake shoes and hardware kit in stock.... may need rotors too, haven't looked but grinding on brake application is noted.
Re: High Miler
« Reply #591 on: June 04, 2017, 05:25:07 AM »
Wow, fail. Haven't touched that. Arb started working again though.
Re: High Miler
« Reply #592 on: June 04, 2017, 05:32:32 AM »
I want a 20" single row on everything I drive. Better than high beams.
Missed this a LOT this trip. It died. I get a tiny flicker when power is applied and removed.
It's been wet inside for a while. I'm sure the board turned green :(
Not sure I'll have a chance to double check power is good before next trip but I don't think I'm that lucky.
Re: High Miler
« Reply #593 on: June 04, 2017, 09:16:13 AM »
Sounds like  a power issue, Let me know after you check power and we can get a new one on the way.
Re: High Miler
« Reply #594 on: June 04, 2017, 01:52:55 PM »
Thanks !!
Re: High Miler
« Reply #595 on: June 05, 2017, 07:14:02 PM »
Least favorite job complete. Took about 75m to tires off with a decent bit of 10#ing
Needs pads and rotors. Weeee
Re: High Miler
« Reply #596 on: June 05, 2017, 09:24:18 PM »
I have found the secret to talking duals off is get a Porta power and push the rims off. Way less effort and cursing
Re: High Miler
« Reply #597 on: June 05, 2017, 10:58:52 PM »
o god getting the 17.5s off the kitchen hauler i had to take two nights at it.  super baseball bat swings with the 20lb sledge
Re: High Miler
« Reply #598 on: June 06, 2017, 08:14:03 AM »
I was wishing for a porta power.
Hub pilots suuuuck
I imagine real truck wheels are even more fun.
Re: High Miler
« Reply #599 on: June 06, 2017, 10:43:20 AM »
I have not had any issues with my dump truck but my 20 ton trailer I think a Porta power is the only way if the person before you didn't put never seize on there
