Author Topic: High Miler  (Read 279305 times)
Re: High Miler
« Reply #195 on: April 01, 2013, 07:46:17 AM »
http://www.michelintruck.com/michelintruck/tires-retreads/load-inflation-tables.jsp
Under 19.5's look at the xds2 in your size. Should give you a nice idea of where you should be for best wear and fuel mileage.
Re: High Miler
« Reply #196 on: April 01, 2013, 10:39:07 AM »
She looks good.
HdR's are rubbing on the rear?
no evidence of touching each other at 105psi with the load of Subis.
they tuck inside the railing of the bed, they've got miles of clearance for travel.
Re: High Miler
« Reply #197 on: April 01, 2013, 10:43:01 AM »
All the way down to 75psi? wow. Things to try!
Re: High Miler
« Reply #198 on: April 01, 2013, 10:44:54 AM »
i run 90 on my truck, its good.
i have had a vibe since they were new at 47mph
Re: High Miler
« Reply #199 on: April 02, 2013, 12:41:43 PM »
new bottom driver seat cushion is out for delivery today. Need to pull the seat and patch the seat cover. that steel frame is COLD on the side of my leg for a couple minutes on a cold night.
px mirror glass is on backorder, but my second favorite supplier had one in stock so that's ordered.
Re: High Miler
« Reply #200 on: April 02, 2013, 12:43:47 PM »
you have a shorter wheelbase. also, the bad section of 90 near BUF is after 190, and between x40 and I481 this side of cuse. those are both better with this truck than dumpbus (I'm 6" longer now. and yes she likes it)
the approaching-Victor piece of 490 is much worse in this truck than the last.
Re: High Miler
« Reply #201 on: April 02, 2013, 01:00:45 PM »
If I'm empty, that new concrete section between Weedsport and Syracuse is BRUTAL with my truck (and our empty box truck at work). You can barely carry on a conversation it shakes you so bad. Add a load and it's fine. Stupid cement.
Re: High Miler
« Reply #202 on: April 02, 2013, 01:02:21 PM »
stupid pavement crew, cement can be well done.
when Troy and I went to Air Cooled in NJ I tried every speed from 40 to 80 and it was unbearable at any of them.
loaded coming back was OK
Re: High Miler
« Reply #203 on: April 04, 2013, 09:28:55 AM »
Thinking about this to solve my gooseneck issue.
http://www.etrailer.com/Accessories-and-Parts/Valley/V69890.html
It's "only" rated for 25k/5k, but looking at scale tickets I think ~5k is the most tongue weight I've ever had. Need to see how 12x14.5" will work with the existing deck hole, I think pretty well. I'm assuming the size is close to the Reese version. http://www.etrailer.com/Accessories-and-Parts/Reese/8339.html
A turnover is the other option, this Reese without rails is a very nice price and rated for 30k/7.5k. No dimensions given and I'm not sure how I'd modify it to actuate from above the bed.
http://www.etrailer.com/Gooseneck/Reese/9460.html
For a little more money yet, this one wouldn't need any modification to use from above the bed. I can't help but think that a sliding pin mechanism would get shitted up a lot faster than a tilt ball mechanism.
http://www.etrailer.com/Accessories-and-Parts/Draw-Tite/6300.html
Re: High Miler
« Reply #204 on: April 04, 2013, 09:31:42 AM »
i was displeased with my B&W latch.  both mine and Matts suck and you need two people to opperate, or some bungi cord paint scratching bushmechanicry
Re: High Miler
« Reply #205 on: April 04, 2013, 09:58:36 AM »
if you are looking for something stationary under the bed I have one very similar to this:
http://www.buyautotruckaccessories.com/product.cfm/cf-bin/pn.curt-over-bed-bent-plate-gooseneck-hitches/
sitting in my barn I would sell to you for $50(plate ball and stationary loops)  It was originally in my 98 F150 I can get you the measurements tonight.
Re: High Miler
« Reply #206 on: April 04, 2013, 10:35:13 AM »
if I'm going to do that I'll just steal parts from my existing setup on dumpbus...
Re: High Miler
« Reply #207 on: April 04, 2013, 10:57:00 AM »
or look at curt
Re: High Miler
« Reply #208 on: April 04, 2013, 11:19:57 AM »
Curt C-52?
didn't see them until I looked by brand. they have a few others too. that's a 30k/6k folding ball.
Re: High Miler
« Reply #209 on: April 04, 2013, 11:22:24 AM »
C52 = new number 61052
$120.. in dayton..
