Author Topic: High Miler  (Read 302614 times)
High Miler
« Reply #180 on: March 27, 2013, 02:58:35 PM »
Useful fire alarm.
awl4928
Re: High Miler
« Reply #181 on: March 27, 2013, 05:30:19 PM »
Looks sweet and the white will hide the salt.
High Miler
« Reply #182 on: March 28, 2013, 11:53:28 AM »
Hide salt/ show rust!!
Re: High Miler
« Reply #183 on: March 28, 2013, 12:37:30 PM »
ya white and rust is not a good look
Re: High Miler
« Reply #184 on: March 28, 2013, 05:29:10 PM »
Please put in some fog lights. I hate fog light caps.
High Miler
« Reply #185 on: March 28, 2013, 05:39:39 PM »
Down the list since the lights aren't bad at all esp for 2 bulb. I agree.
High Miler
« Reply #186 on: March 30, 2013, 12:24:36 AM »
Gotta rebuild the goose hitch on this bad boy. Under spec'd for previous life, and future usage.
High Miler
« Reply #187 on: March 30, 2013, 10:35:16 AM »
Tahrs are schweet
High Miler
« Reply #188 on: March 31, 2013, 11:58:04 AM »
Didn't do too badly with the first real load. I can definitely tell its shallower gears, and it seems I'm at 100% at about half pedal, the rest of travel doesn't do much. I'll be in 5th on real hills no doubt. I was in 3rd through downtown list to keep it above 1500 at 40. Haha.
Tires are about 5.9% taller.
Can definitely tell the tires are wildly heavier too. Above 60 is ride degrades a bit. Can tell the additional unsprung rotating weight is there. Very little squirm though especially compared to the last new set. Duals are close but made no contact, they're at 105psi. May drop that a bit. Jared, what would you say would be safe minimum? 90?  I was thinking of trying 90 rear 100 front and see if it smooths out a bit. The shoulders of the drives don't touch empty right now. Steers do.
Re: High Miler
« Reply #189 on: March 31, 2013, 12:05:04 PM »
Looks good
High Miler
« Reply #190 on: March 31, 2013, 01:53:38 PM »
Where's the subies goin?
Re: High Miler
« Reply #191 on: March 31, 2013, 02:37:19 PM »
I can get you some inflation tables Monday. Should show you exactly where you should be.
Re: High Miler
« Reply #192 on: March 31, 2013, 02:49:30 PM »
who you towing for?
High Miler
« Reply #193 on: March 31, 2013, 09:35:05 PM »
Auction buys for jake out of Adesa Syracuse.
Re: High Miler
« Reply #194 on: April 01, 2013, 07:38:46 AM »
She looks good.
HdR's are rubbing on the rear?
