Author Topic: 1973 CJ6  (Read 171407 times)
« Reply #690 on: September 19, 2015, 03:12:12 PM »
passenger side slider mocked up...
the supports are horizontal going into the frame.. have >1" gap from op of slider to body edge..
without altering the sliders this was as tight as I could get them to body.. my body mounts are a bit taller than stock...
I have a thought about a vertical support, integrating it into the roll cage...
ohh SMike ;)
« Reply #691 on: September 19, 2015, 10:37:12 PM »
Look good.
« Reply #692 on: September 20, 2015, 12:07:38 AM »
That seems pretty reasonable. Triangulation or cage support should keep them there and prevent upward migration.
« Reply #693 on: January 06, 2016, 11:10:38 AM »
Jeep is nestled in the garage for the winter..
was hanging out there last night, sitting in the seat making motor noises when I noticed my brake lights weren't lighting up.. end sup I had 2 blown fuses.. Brake lights and Turn signal..
couple of WTF's and a drink later I traced my footsteps to the last thing I did before I put the Jeep away....
Slider frame bolts cant be used as wire clamps..  :o
Winter to do List:
Things that need correcting
-Fuel Lines need re flaring
-Steering shaft needs set screws drilled
-Was running rich when parked, TBI adjustment before spring driving
-Excess heat under the hood.. louvers, coolers, don't know where this one is going
-Change fluids all around
-Re Seal Tcase oil pan
-Tcase shifter angle
-Horn button / column connection
Things that need completing
-Hazard Switch wiring
-Washer pump wiring
-E brake adjustment
-Soft top drilling and install
-Rear bench
-Slider to cage tie ins
-Sliders and seat mount painting
-Shifter tunnel / boots
« Reply #694 on: January 06, 2016, 11:22:03 AM »
boy that looks familiar.
and reminds me that I owe you a writeup. wonder if I'll ever get that done...
« Reply #695 on: January 06, 2016, 12:02:16 PM »
if the TBI has a working O2 and respective sensors and everything is happy, don't forget its not a carb and wont "run rich"
« Reply #696 on: January 06, 2016, 01:33:06 PM »
Howell thinks there too much pressure and TBI might need to be dialed down a bit..
Im not really going to mess with it until the spring when I can road test and check system info on scanner...
« Reply #697 on: January 06, 2016, 02:44:00 PM »
relief ball in that TBI is huge and way over sized.  pretty hard to hurt it.  same 90 psi pump on 571 now that ran a TBI and now runs PFI system
« Reply #698 on: January 14, 2016, 12:26:51 PM »
Found some flares in my parts stash and am looking at my options..
I am certainly looking to keep a stock profile, but I have never been a fan of molded flares.
unless I decide to make something, a metal flare in the rear is only available with <3" of coverage, and fronts are usually integral to the fender...
just brainstorming here if anybody has an insight...
« Reply #699 on: January 14, 2016, 12:34:20 PM »
I don't think I'd be looking to put flares on that. looks too clean without.
« Reply #700 on: January 14, 2016, 01:47:57 PM »
I disagree.  I think the clean set of original CJ flares will look great.  It breaks up the large flat body panel nicely and doesn't look out-of-place.
Or nothing.  No pocket flares, tube flares, or anything of that nonsense on this resto-mod.
« Reply #701 on: January 14, 2016, 02:26:41 PM »
I completely agree with Mark.
« Reply #702 on: January 15, 2016, 09:57:03 AM »
I kinda really just wanted a tube fender/rub rail...
just nobody makes one that's smaller then 3"
« Reply #703 on: January 15, 2016, 10:25:50 AM »
If this will see tree and rock duty, have sMike or someone use a tubing roller and 1" tube.  That will allow a little bit more space for the end bends.  I have some 1 x .188(?) stock that isn't doing anything if you want to try it.
« Reply #704 on: January 15, 2016, 10:43:16 AM »
even if it sees it once... I drive by braille
not use to a LWB... way more concerned about the ass end than the front
