Author Topic: 1973 CJ6  (Read 149944 times)
« Reply #585 on: February 27, 2015, 04:17:48 PM »
hmm thats interesting i bent 120wall with it all day long when it says 105 max
« Reply #586 on: March 01, 2015, 07:56:12 AM »
Anybody have one of these I can borrow....
Ready to freak out on my brakes....
« Reply #587 on: March 09, 2015, 10:42:20 AM »
a defective wheel cyl will make bleeding brakes impossible...  :-\
« Reply #588 on: March 09, 2015, 12:57:58 PM »
That will do it!
« Reply #589 on: March 16, 2015, 06:44:18 PM »
This is everything...
Distributor
30-4891 Reman
80-4891 New
Coil
FD476, Better quality Standard.. if you must use a HP coil, accel or flamethrower.. just get canister type.. (store in Land rover thread)
Cap, Adapter, rotor
FD168
FD156
FD177
Ignition control mod..
LX235
All the plugs and connectors are available at parts stores..
just for a visual I posted links..
Here is your coil horseshoe
Here is your distrib plug
Weather Pack Connectors for ignition control mod.
you only need male or female.. just forgot..
FD177 is a smaller diameter cap.
I'll email James tomorrow about the rotor#  if your still traveling.
« Reply #590 on: March 20, 2015, 11:13:44 AM »
Need to get some mental organization...
Jeeps almost to the point where its streetable...
ran into some issues with brakes/cooling.. easy adjustments, just time consuming.
Running list..
    Mechanical
    • Brake Prop Valve (NOS unit)
                 MC pushrod final adjustments needed
    • Manifold heater hose fitting (nos)
                 Move Howell sensor, mechanical temp gauge
                 New Coolant line to bulkhead
                 Under dash heater unit
                 AC lines
    • Washer nozzle in cowl
    • Hood
                 Prop rod paint
                 Hood catch, drill out and galvy
    • Tailgate
                 paint
                 Drill and mount latches
    • Roll Cage / seating
                 Tweak above drier/passenger
                 Seats mounted
                 Harness mounts
    • ARB
                 Mount compressor
                 plumb air lines
    • Brake light switch
    • Front bumper ideas, rear tire carrier
    • Winch options
    • Wiper linkage adjustment
    • defroster ducting
    • air cleaner / intake
    • Power steering pulley, need OEM
    • 5 lugs per wheel would be nice
    • TRE flip for draglink
    • E brake adjustment
    Wiring
    • Dash Wire
                  Hazard Switch
                  Gauge
                         -Cluster
                         -Mechanical temp/oil
    • Hi/Lo Floor switch
    • Washer pump
    • horn
    • Directional
                  weather pack connector
    • ARB wire
                  switch pod
                  compressor
    • Radio / Speakers
    • chassis, dash and engine loom (aka, make pretty)
    « Reply #591 on: March 20, 2015, 04:00:36 PM »
    That's not tooooo bad of a list.
    « Reply #592 on: April 02, 2015, 10:38:51 AM »
    looking for some ideas....
    the way my cage and seats will probably end up mounting I will loose easy access to my under seat toolbox.
    At first I was thinking the ARB compressor.. The thought of heat buildup, even without the lid came up..
    Its also welded very well.. if I ever submerged it would easily fill with water..
    Here is a picture the way it sits now...
    any ideas on how to use this otherwise wasted space?
    « Reply #593 on: April 02, 2015, 10:46:54 AM »
    I wouldn't think you'd want a noisy compressor right under you...
    You'll probably want to put a drain hole in it anyway, though.
    « Reply #594 on: April 02, 2015, 10:54:54 AM »
    who put those stupid seat mounts there?!?
    fill it with money
    « Reply #595 on: April 02, 2015, 03:28:34 PM »
    thought of a piggy bank did cross my mind, but the coins would make more noise than the compressor ever would..
    Im not running an air tank, jut the comp hooked to the 2 lockers...
    Drain hole and remote filter maybe ?!?!?!
    found this image on the testing of my compressor..
    I should be able to treat it like an electric fan.... killing the power if I drown...
    « Reply #596 on: April 02, 2015, 03:32:54 PM »
    If you are going to put it there, use the extra space for a small air tank?
    « Reply #597 on: April 07, 2015, 10:42:27 AM »
    Got the heater unit mounted..
    AC and Coolant lines plumbed to bulkhead
    need to wire AC/Heat on a separate circuit, thus another custom harness..
    for a "painless" system I have been doing a lot of additional harnesses....
    Head some issues with the speedo cluster.. should have those remedied shortly..  Issue with self grounding cluster lamps and too much aftermarket plastic...
    Hood painted and on truck
    hinges needed some reaming to remove the galvy and I press fit the 2 part hinges with moly engine lube..
    yes, the hood wont be pull-off-able.. but it will be secure and hinge-able..
    Aqualu provided shims to compensate for radius curve of cowl.. ordered hood rubbers and cowl/hood seal from a YJ before final adjustments are made.. (trimming shims and final placement of hood)
    « Reply #598 on: April 07, 2015, 10:46:59 PM »
    Have I said how much I love that color? Dam!
    « Reply #599 on: April 08, 2015, 09:11:53 AM »
    have I mentioned how much I hate doing things twice..  >:(
