Author Topic: 1973 CJ6  (Read 170944 times)
« Reply #555 on: December 08, 2014, 09:23:11 PM »
I have to spend some time with it....
« Reply #556 on: December 08, 2014, 11:16:02 PM »
id feel comfortable with another 1" or so for me.  maybe its good.  at the very least throw some padding on it.
short of pulling sliders to get back 1.5" not sure besides different seats like we did with eds.
« Reply #557 on: December 09, 2014, 07:46:12 AM »
I think I might have found an extra inch....
Have more time to spend on it when LR get the hell out of my way...
« Reply #558 on: December 09, 2014, 09:28:51 AM »
was up at the warehouse this AM and noticed the seast in my YJ...
I think with a decent rake instead of being flat mounted on floor, Might be able to grab another inch or so..
Im also going to grab one of the fiberglass doors I have to mark on the tub where the door jam/top begins..
My YJ doesn't have sliders, but it has a wider door opening..
« Reply #559 on: December 09, 2014, 09:32:12 AM »
rake isnt going to help unless the floor goes away in the back
« Reply #560 on: December 12, 2014, 07:40:09 AM »
just for reference later...
Quote from: jeepermc;1181963
Approximately 44.25 from floor to top of b pillar. 1.25 from top of tube to the lowest point on the top
« Reply #561 on: January 06, 2015, 09:29:23 PM »
« Reply #562 on: February 12, 2015, 02:26:45 PM »
dusted this off last night....
need to refocus efforts and get another to do list going...
« Reply #563 on: February 21, 2015, 03:55:06 PM »
Back in the limelight...
started tearing into the "issues"
Brakes
Power Steering
Radiator
« Reply #564 on: February 22, 2015, 09:55:45 AM »
What did you end up going with for distributor and coil choice?
I fried our coil again (left ignition on too long) we are on coil #3.
This time it died 20 minutes out into the desert.
current set up is a Mallory Optical Distributor and Accell Super coil.
New plan is to swap in a DUI distributor/ coil.
$299.00 50 K volts eliminates the ballast resistor also.
I assume it's a standard GM one wire setup?
« Reply #565 on: February 22, 2015, 12:49:33 PM »
you're overthinking it...
STOCK ignition system is the best thing for these motors..
duraspark ignition might have been the best thing to come from ford since the model T...
DO NOT GO DUI...  they were never meant to be in these motors..
What "year" ignition system are you running?
« Reply #566 on: February 22, 2015, 06:14:16 PM »
I've read the exact opposite opinion for ignition systems on the amc 360.
I don't know what year system we are running. Not sure of the difderences.
DUI set up seems much simpler, less wires and more readily available! This motor didn't come to us with a stock ignition.  So i have nothing to compare it to. Just looking for more reliability and simplicity.  Power increase is second on the list.
« Reply #567 on: February 22, 2015, 07:10:37 PM »
A GM HEI was never meant to run in an AMC motor..
the distributor drive gears are welded or pressed on to the GM shaft.. weakness..
DUI's are well known for being weak in the area...
AMC V8 motors are known for eating cam/distrib gears if not properly broken in / or matched..
on a stock motor the Duraspark and TFI (wide cap) distributor are more then enough juice to keep things spinning..
K.I.S.S
I mocked a 1988 Grand Wagoneer ignition..  essentially the same on the YJ.. so I knew what I was doing..
(distrib, coil, ignition mod)
Cap and rotor from 77-87 ish ford V8 (larger cap)
wires and plugs and DONE.  off the shelf reliability
want me to get you a parts list.. I have in the office..
from my bookmarked notes:
"There's probably as much or more hype over coils than most any part of the ignition in the aftermarket. If it takes 30k volts to fire a spark across the plug gap, it doesn't matter if it's a 40k volt, 35k volt or 50k volt coil...it will put out 30k volts. The problem with voltage is if the plug gap is too big and it requires more volts to cross it, then a higher volt coil can do the job where a less coil capable can't. In a well tuned engine a super high voltage coil isn't needed as much as a coil with a fast saturation time."
« Reply #568 on: February 22, 2015, 07:13:15 PM »
if you burn a DUI unit @ Rauch where you going to get a new one???  its about 2 hrs to Quadratec..
Burn a ford distributor and your good at most parts/chain stores
« Reply #569 on: February 22, 2015, 07:22:28 PM »
more ls less AMC      :-X
