Author Topic: 1973 CJ6  (Read 170943 times)
« Reply #495 on: November 25, 2014, 01:47:34 PM »
Sliders ordered...
still looking into restraints.
« Reply #496 on: November 26, 2014, 01:48:55 PM »
try to get those dimensions for Thursday night.  plan to start Friday and get cage tacked up.
« Reply #497 on: November 26, 2014, 02:32:17 PM »
will be loading and posting a compellation of measurements and pictures.
« Reply #498 on: November 26, 2014, 04:02:54 PM »
ok....
I asked on ECJ5 for a soft top measurement since I don't have access...
Quote from: timgr;1178677
Grabbing my tape ... the bottom of the center of the bow is 45" to the flat part of the floor between the ribs.
Looks like the 46" I measured from the load floor to the bottom of the roof pans out..
when I measured from the bottom of the driver footwell to the top of the windshield frame I got 46" as well..
as you can see the top actually goes up higher than the windshield frame, but the soft tops would start just a hear over the 46"
Ill be in the office Friday and can measure anything since I have the CJ6 across the street here.
« Reply #499 on: November 27, 2014, 10:25:30 AM »
ok need advice as to what kind of restraints..
I am running Mastercraft seats.. same as in the YJ...
Should I go full 5 point harness?  if so how is it dealing on the street?
« Reply #500 on: November 27, 2014, 10:31:54 AM »
Could do both but messy.
« Reply #501 on: November 27, 2014, 11:11:58 AM »
If it matters to you, I've heard rumors that 5 point harnesses do not qualify as seat belts in some states. Seems ludicrous but worth a check if you care. I wouldn't.
For daily use I'd go cam lock style instead of latch n link. Friendlier and less apt to pinch clothing. More like a factory belt experience.
If it's going to get wheeled, or you want the impression of a true offroad rig, I'd suggest 5 points. With a camlock, 2" shoulder straps, and "pull up" adjustment on the lap belts I don't think you're giving up much.
« Reply #502 on: November 27, 2014, 02:00:51 PM »
I think NY is one of those states.
« Reply #503 on: November 27, 2014, 02:45:00 PM »
issue with them is DOT regulated as they are NOT OEM..
in case of an accident lawyers will absolutely go after everything that isn't iron clad..  no matter what state you are in.
think a GM recall is messy??... imagine getting hit in your ride with 5 points, passengers or yourself getting injured and the other party would not be liable since the belts weren't OEM installed..
having said that... I would trust my safety in a 5 point with a cage on and off road..
just didn't know the viability of them for adjusting radio, coffee, kids, etc....
« Reply #504 on: November 27, 2014, 03:16:57 PM »
They Will definitely limit your reach when they are adjusted tight enough to actually work correctly.
I put a set of corbeu in a CJ restoration I did a few years ago. It was a hybrid design.
Double shoulder harness design that latched similar to regular lap belt.
Better than OEM IMO.  But somewhat annoying to get in and out.
« Reply #505 on: November 27, 2014, 04:24:43 PM »
Can't beat an OEM retractor setup for radio and coffee needs. A 5pt that's tight enough to do its job really really keeps you put
« Reply #506 on: November 27, 2014, 05:36:08 PM »
« Reply #507 on: November 28, 2014, 10:32:55 AM »
need that measurement from the side rail to the middle hoop and the rear hoop also like we talked
« Reply #508 on: November 28, 2014, 10:41:33 AM »
The 4.3 work well, Had them in the Profender buggy for the Kids, and I think Gif has them in his buggy.
http://prpseats.com/product/4-2-harness/
« Reply #509 on: November 28, 2014, 12:50:42 PM »
no roll bar in the truck....
from rail to rain gutter on hard top is 28"
measured from here... right by door opening
total height of roof from side rail is 32"
from rear of load floor to opening of rear door is 40.5
