Author Topic: 1973 CJ6  (Read 170927 times)
« Reply #465 on: October 20, 2014, 03:23:37 PM »
yes..
will take tonight
« Reply #466 on: October 21, 2014, 10:28:00 AM »
New to do list...  subject to edit.
Clean interior of tub/work space
Engine / compartment:
Wire loom, fit and finish
ARB compressor, mount and wire
Spark plug wire organize
complete exhaust
Body:
Body mount bolts, torque
Washer nozzle
mount air exchanger
Coolant and AC lines.
defroster ducting
Suspension
Torque suspension hardware
Electrical:
Dash wire, complete
Radio/Speakers, install & wire
Aux switch pod, install and wire
Turn signal switch
Hazard switch
Misc fab / M4
E Brake cable bracket…
Cage and seat mock up
« Reply #467 on: October 27, 2014, 08:27:06 AM »
some light work done this weekend...
Speakers, head unit, and switch pod installed.
no wiring tackled.. need to shift focus to that if this is ever getting done.
« Reply #468 on: October 28, 2014, 11:19:54 AM »
I think we found the blinker issue....
 trying @ lunch today.. cross fingers
« Reply #469 on: October 28, 2014, 01:08:24 PM »
« Reply #470 on: October 28, 2014, 01:54:21 PM »
I think the issue is more like a lack of knowledge about blinker circuits and circuits in general..
« Reply #471 on: November 03, 2014, 07:55:30 AM »
Slight change of plans in the dash area...
I have decided to ditch the OEM style gauges in favor of an aftermarket mechanical water and oil pressure gauge.
After removing the Crown gauges all electrical issues seem to go away..
Either I had a crossed wire or something was just goofy..  Fewer wires back there and engine vitals will be accurate.  Originality will have to be compromised..
Lights are working!!!
Turn signal functioning properly, brake light and reverse.
Headlight and High Beams looking good... no goofiness anymore since double filament bulb was wired correctly.
I even got the green light in the Sparton and the correct directional arrow to illuminate. :)
Really like these taillight.. They are LED Brake/Turn/Parking/and BACKUP..  Single diode light is in the red diode matrix.
Really lights up the garage at least..
My Land Rover lessons are shining through everywhere on this Jeep..
Riveter was broken out for the aux switch panel.
« Reply #472 on: November 03, 2014, 12:12:15 PM »
Originality is getting compromised?
You feeling ok?
« Reply #473 on: November 03, 2014, 12:15:45 PM »
those speakers lol
« Reply #474 on: November 04, 2014, 11:41:51 AM »
if you happened to want another 6 to go along with this one..
1964 Willys Jeep CJ-6 Original Survivor 5,000 Miles! - $9500 (Red Lion,Pa)
http://york.craigslist.org/cto/4725852867.html
« Reply #475 on: November 04, 2014, 12:33:30 PM »
some more originality came in the mail today  :)
« Reply #476 on: November 10, 2014, 10:22:46 AM »
exhaust all finished up...
parts of it aren't the straightest shot, and its not the largest diameter pipe, 2.25", but its bigger than factory and nice and neat.  Shouldn't be that restrictive :)
The system takes a sharp turn up after the stock Y pipe.
Flowmaster tucked high up out of the way..
View from the side frame rail.
Hugs the rear tank clearing the bump stop mount
Exits the rear flush with the rear cross member.
« Reply #477 on: November 11, 2014, 09:34:11 AM »
Assembly required skid...
« Reply #478 on: November 13, 2014, 10:26:22 AM »
can you wrap the paint in bubble wrap for me  :-\
« Reply #479 on: November 13, 2014, 11:06:30 AM »
yup
