Author Topic: 1973 CJ6  (Read 172335 times)
« Reply #345 on: April 02, 2014, 10:55:30 AM »
Easiest way is drill then file.
yeah.. I figured..
just swept and vacuumed yesterday too... time for more aluminum to fly..
« Reply #346 on: April 03, 2014, 08:09:55 AM »
Hey are those down pipes from Nuway?
Starting my exhaust shortly and not able to use cora's old ones?
« Reply #347 on: April 03, 2014, 09:02:14 AM »
should be.. they stopped producing but we might have more.
« Reply #348 on: April 03, 2014, 09:10:48 AM »
mocked up the mastercraft seat last night and albeit comfy, it’s a tight job in there...
stock brackets might not cut it, expensive suspension seats might not cut it…
trying not to get hung up on this and deal with it later..
« Reply #349 on: April 03, 2014, 09:33:42 AM »
Couple of threads I've been reading mention a shorter version of the seat from a side-by-side, ie: RZR.  They give you about 3" more leg bend room.  Don't know if that's where the space is needed.
« Reply #350 on: April 03, 2014, 10:00:06 AM »
These jeeps were tight from the get go..
Using a high back seat may not be the best thing without modified seat brackets..
It's the huge school buss wheel and non tilting column that are an issue.. not to mention the small door opening, short legs and growing thighs of the operator.
« Reply #351 on: April 03, 2014, 01:50:49 PM »
K thanks I'll call Robyn
Can you confirm years?
I lol have to verify w cora what year her motor is.
« Reply #352 on: April 03, 2014, 02:17:27 PM »
Have not been to NuWay in a while?
« Reply #353 on: April 03, 2014, 02:29:56 PM »
Stopped in a few times over the last month or so but typically after normal business hours is Robin not there anymore?
« Reply #354 on: April 03, 2014, 02:33:25 PM »
No, James is the man now.
Robin went to the new Victor Chevy. Offer she couldent refuse. Sad day......
« Reply #355 on: April 03, 2014, 09:28:18 PM »
Yeah robin went to victor Chevy as the new parts mgr..  Great move for her, but I do t think she's happy....
Meanwhile we just hired her daughter in accounting....
« Reply #356 on: April 04, 2014, 08:24:27 AM »
Robyn will be missed.
James is the man IMO.
« Reply #357 on: April 05, 2014, 10:10:54 AM »
Thanks for getting James the part #.
I can't see the mating surface in photos but these do mate to factory manifolds?
I'm not familiar with the stock design
The flanges that cora had were home built by the previous owner and we're warped and never sealed correctly.
Was planning to buy these and cut them up for the flanges and pipe ends.
« Reply #358 on: April 05, 2014, 12:13:56 PM »
ill take some pics.. I should be all buttoned up with this shortly..
I am using the stock heat riser however...
the Y pipe will bolt directly to the factory manifolds regardless, just need to use the same gasket on each side vs the flange setup...
« Reply #359 on: April 08, 2014, 03:20:17 PM »
batchlor (but still father of 2) for 2 nights...
might get some stuff done...  might not  :-\
