Author Topic: 1973 CJ6  (Read 171121 times)
« Reply #315 on: March 06, 2014, 08:34:33 AM »
you should look at my land rover thread...  ;)
i'll get something together... post in tech.. but untill I do just ask if you need anything.
« Reply #316 on: March 06, 2014, 05:32:23 PM »
Manifolds in... snug as a bug in the engine compartment.
need to find some brass plugs for the air tube ports..
ARP bolts were way to huge.. stock ones worked well.
The Remflex gaskets are awesome and sealed tight.
« Reply #317 on: March 06, 2014, 05:49:24 PM »
Looks like the body really needs 1/2" up/back to get off the manifolds. even tighter than the valve covers
« Reply #318 on: March 06, 2014, 06:56:10 PM »
optical illusion and reflection...
manifolds went on no issue, no wiggle..
(with the fender off)
« Reply #319 on: March 07, 2014, 10:34:27 AM »
Damn thats a sweet looking motor.
« Reply #320 on: March 11, 2014, 09:38:59 AM »
spoke to larry @ custom truck yesterday about a spray in liner...
I think im pulling the trigger on this..
« Reply #321 on: March 11, 2014, 09:44:59 AM »
can you PM me the ball park cost if that was discussed so i can pass to ED, he might also be interested in doing his 5
« Reply #322 on: March 11, 2014, 09:46:15 AM »
400 - 600
all depends on masking form what I understand.
« Reply #323 on: March 24, 2014, 09:12:43 AM »
Have been a bit slow on this guy the past 2 weeks...
have a few hold ups and hang ups that caused a few speed bumps.
Had to get a correct pedal assembly in the truck..
the later CJ one would have required too much modification where safety would have been compromised.
Here is a 72-75 assembly modified to a hydraulic clutch, mocked up with a spare steering column.
Needed some more meat on the pedal assembly to fit the larger brake booster bracket...  off to powder coat and should be back for this week.
Ran into a little bit of luck finally...
the 76-79 Y Pipe we had in stock fits nicely in the frame..
might have some clearance issues with the front driveshaft, but that can easily be modified.
Its enough to get the motor running and the exhaust going back...
Got to mocking up the radiator and condenser.. Didn’t want to be drilling any holes in fresh paint.
Took some strap steel to make some initial brackets, will be remaking them in 1/8" plate
Radiator fits nicely in stock location and there is a nice air gap between the Radiator/Condenser..
I might try and make an air damn on the top and bottom, or perhaps a rubber seal to direct air flow..
Body fitment has been difficult and easy all at the same time.
once I got the thought out of my head about cutting as little as possible the job got easier  ;D
the drive train holes were the trickiest..
A tucked up 4 speed and a twin stick where a twin stick never was.
I have heard stories of a bolt head coming into contact with a tub and making noise like everything was falling apart.. I was making sure that wasn’t going to happen here.
Cut some relief areas to make field adjustments if necessary and make removal easy if need be.
I don’t really have any good pictures but since the D300 is a bit larger than the D20 and my driveline is tucked up into the frame I needed to cut some relief areas in the aluminum floor supports for one area in particular where they were just kissing..
I’m already on 1.25" rubber mounts where .625" is stock.. I wasn’t going any higher...
Starting to button up loose ends on the engine/drivetrain
Mean Green starter installed (I don’t know how the stock one would have fit)
Stock height cast valve covers installed
Dipstick and brackets painted and touched up (installing was a p.i.t.a)
Fuel injection system arrived...
« Reply #324 on: March 24, 2014, 09:23:14 AM »
Wait.  Condenser?  This is going to have A/C?  That will be sweet!
« Reply #325 on: March 24, 2014, 09:36:35 AM »
o no not another bastardized mismatch system using GM parts!
« Reply #326 on: March 24, 2014, 09:44:33 AM »
That's why I didn't build this motor with a cam and bumped compression..
On stock motors it's just an electronic carburetor..
« Last Edit: March 24, 2014, 09:54:15 AM by rejeep »
« Reply #327 on: March 24, 2014, 05:10:23 PM »
That's really coming together nicely!
« Reply #328 on: March 25, 2014, 09:16:15 AM »
Roll cage:
Smike.. how do you determine how wide a hoop should be?  is there a golden equation or rule of thumb?
« Reply #329 on: March 25, 2014, 09:17:33 AM »
for a CJ thing, as wide and as big as possible to fit inside whatever top your running
