Author Topic: 1973 CJ6  (Read 172333 times)
« Reply #360 on: April 08, 2014, 03:38:00 PM »
no way!
« Reply #361 on: April 12, 2014, 08:57:58 AM »
Running "TO DO" list
Engine:
Howell
Exhaust manifold plugs (copper washer)
Y pipe (gaskets & valve)
Cooling fan (fan clutch)
Paint dipstick bracket and touch up dipstick
Transmission / Tcase:
Slave Cyl.
Fork boot
Paint touch up
Inspection cover
Shifter installs
Driveshaft (order & front Y pipe alteration) (M4)
Body:
Radiator/condenser mock up in grill (1/8” plate)
Steel painting (grill, hood, fenders, hinges)
Floor support trimming for Tcase (flap wheels)
Windshield hinge drilling
Wiper linkage
Tailgate and hinges
Pedals (rebuild)
Column (adjustment for seats)
Column bracket (drill)
Tub liner (getting yanked around by custom truck.. still waiting for a date)
Firewall insulation
sand and polish
Seats: (Smike.. I will prob need help with this and cage install....)
Type (Corbeau and Mastercraft)
Mounting (stock mounts)
Sliders or not
Misc.
Wiring (painless?) purchased
Dash gauges (searching for NOS)
more to do:
EBrake pedal and cables
speedo cable
Windshield assembly
steering column assembly
"road prep"
AC unit bracket (M4)
Battery tray
« Last Edit: April 12, 2014, 09:08:48 AM by rejeep »
« Reply #362 on: April 14, 2014, 10:21:03 AM »
Some progress made while the wife was away and over the weekend..
Decided to take the body off, hopefully for the last time and start getting the frame and running gear in order.
Delays with the tub liner application was the primary reason for this, but will also give me some peace of mind that things can be crossed off the list for good.
New AA speedo adapter installed with correct gear and VSS for the Howell
T18 and Dana 300 Shifters installed
Filled with GL4 and ready to go..
Exhaust all sealed up
Copper crush washers and bolts installed in manifold
Heat riser installed
Started buttoning up the gas tank and skid
A bit flimsy compared to my YJ skids, but trying to keep a stock feel to the truck
Fuel pump and filter mounted with a little help from my wife’s old yoga mat.
Filler hose and vent line from MTS installed…
Power steering lines run and new Borgeson lower joint installed..
Very tight fit on the steering gear, I guess I’ll appreciate it @70 mph..
Started to plan out a custom bracket for the under dash unit, I wasn’t too thrilled with the “universal” ones supplied by Jeep Air…
Condenser installed in grill with some custom brackets as well, perfect gaping between the condenser and radiator..
« Reply #363 on: April 14, 2014, 10:27:39 AM »
Steering column being rebuilt..
stripped down the tube and coated in some grease to keep from rust scaling.
New lower and upper bearings installed, all NOS, amazing the quality difference in the upper bearing..
horn contact repaired, sleeved and wired.. soldering iron wasn’t getting as hot as it should so the blob happened.
plastic contact restored, re-drilled and riveted with a new wire terminal attached.
Would have finished, but didn’t have a new horn button handy..
« Reply #364 on: April 14, 2014, 11:07:01 AM »
The shifters and bracket look really nice. That's almost exactly how I want to redo mine on 571. Interlock pills are getting modified and leverage and throw are going to increase significantly.
« Reply #365 on: April 16, 2014, 01:26:55 PM »
I might be ready for some M4 love..
cage/seat brackets...
« Reply #366 on: April 17, 2014, 10:15:31 AM »
200 lbs of DOM dropped at the Dock...
warehouse kid thought it was exhaust and started shelving it.... :o
« Reply #367 on: April 17, 2014, 10:30:39 AM »
HD exhaust!
« Reply #368 on: April 28, 2014, 09:42:28 PM »
Engine:
Howell
Slave Cyl.
Fork boot
Paint touch up
Inspection cover
Shifter installs
Body:
Wiper linkage
Tailgate and hinges
Pedals (rebuild)
Firewall insulation
sand and polish
Sliders or not
Misc.
more to do:
speedo cable
Windshield assembly
"road prep"
Battery tray
« Reply #369 on: April 28, 2014, 11:05:39 PM »
That list is getting really short!
« Reply #370 on: April 29, 2014, 09:07:07 AM »
need to make it longer...   ::)
« Reply #371 on: May 01, 2014, 08:35:43 AM »
loaded the body on the trailer last night to head over for some finishing...
« Reply #372 on: May 01, 2014, 08:55:08 AM »
man you are brave with those little hooks and an aluminum tub
« Reply #373 on: May 01, 2014, 09:13:46 AM »
i dont think you realize how thick the metal is..
« Reply #374 on: May 01, 2014, 09:20:53 AM »
i have seen you tow though!
