Author Topic: 1973 CJ6  (Read 170983 times)
« Reply #180 on: December 01, 2013, 01:42:33 PM »
D30 Front..
3.73 gears
ARB locker, 30 spline
RCV 30 spline shafts
Moog and Wagner chassis and brake parts
Rebuild with all new Timken bearings and Seals...
1982 CJ7 disk brake knuckles w/yukon HD spindles
Superwinch premium lockout hubs.
« Reply #181 on: December 01, 2013, 04:01:47 PM »
One of these is not like the others/ One of these just doesn't belong.
Options are pretty limited unless you go to a unit bearing though, right? There was no D30 internal locking hub? With the ARB I'd probably just run drive flanges with grade 9 bolts. I'm recalling the external lockout issues that were had on other rigs here with bolts loosening and breaking. Wasn't that Ryan's scout 44 front that also had unending spindle bolt issues as well?
« Reply #182 on: December 01, 2013, 04:44:03 PM »
nope..
30 spline inners
27 spline outer..
didnt want to go 30 outer for 2 reasons..
 1. availability of spares..
 2. wanted to make the weak link be the outer stub that is more easily fixed on trail...
     one spare stub, lockout, spindle will work for both sides..
there are 30 spline lockouts and a 30 spline stub available...  gives me something to upgrade to :)
« Reply #183 on: December 01, 2013, 06:23:55 PM »
Yea, mine broke many times, I believe Cora had issues with hers as well.
« Reply #184 on: December 02, 2013, 09:37:38 AM »
i broke lots of hubs and then ring gears
« Reply #185 on: December 06, 2013, 07:54:53 AM »
heading home.
« Reply #186 on: December 06, 2013, 08:35:22 AM »
I'm available for CT to Roc transport if ever needed!
« Reply #187 on: December 07, 2013, 07:37:50 PM »
Intake oil baffle issues...
fabrication required...
« Reply #188 on: December 12, 2013, 11:35:58 AM »
intake baffle cleaned, mangled and riveted into place...
Bulltear engine parts finally came in today...  will hopefully get some work done on the motor this weekend..
« Reply #189 on: December 15, 2013, 01:59:36 PM »
Started dressing the engine this weekend...
and after about 3-4 hrs....
still haven't decided on valve covers..
need to build oil pump and test for pressure...
figuring out acc. brackets and pulleys might be interesting as well.. have a box of parts and bolts that need to be sorted out.
There was some guesswork on the oil pan and pickup tube..
seemed a bit loose in the threads and I need a much better in. torque wrench for the pan bolts..
I might be pulling and re sealing this week...
« Reply #190 on: December 15, 2013, 04:38:16 PM »
U still need pics?
Coras is still complete on the hoist!
« Reply #191 on: December 15, 2013, 07:18:20 PM »
Yes..   I have a pile of brackets and boots with no road map..
« Reply #192 on: December 16, 2013, 11:30:07 AM »
oil pan needs to come off...
« Reply #193 on: December 16, 2013, 11:49:48 AM »
Ok ill snap some tonight depending on how late I get home
« Reply #194 on: December 16, 2013, 07:49:03 PM »
I apologize for the mud.
