Wonder goes to Rausch
4
Topic: Wonder goes to Rausch (Read 11248 times)
Re: Wonder goes to Rausch
Reply #30 on:
February 14, 2012, 11:20:54 AM »
cracker, you have all the parts you need, case and rear shaft, bolt on swap?
Free Loader
Reply #31 on:
February 14, 2012, 11:31:54 AM »
shaft needs shortening and possible skid plate massaging... here is a good write up..
http://www.jeepforum.com/forum/f9/241-rock-track-install-into-97-tj-399875/
things it does not answer:
1.) is pinion angle, I am not sure if that will need to be corrected. If so how.. I do not currently have adjustable arms
2.) I really would prefer to get rid of the t-case drop so I probably need to do the body lift or see if we can massage the floor to make it fit.
Reply #32 on:
February 14, 2012, 11:39:12 AM »
meh, ok.
sounds like work. I think mine is going to get pulled tonight and take apart. something has to be bent or messed up.
Free Loader
Reply #33 on:
February 14, 2012, 11:41:30 AM »
Shouldn't need a body lift if no tummy tuck. Definitely dump the t-case lowering spacers. If you have a CV in the rear shaft already, your pinion should be within 2 degrees of shaft angle.
Free Loader
Reply #34 on:
February 14, 2012, 12:22:14 PM »
putting the 241 on a 231 skid plate causes the case and the shift linkage to hit the tub
I don't currently have CV.
jacel86
Free Loader
Reply #35 on:
February 14, 2012, 01:13:19 PM »
Need a Rubicon skid plate? :-D
Free Loader
Reply #36 on:
February 14, 2012, 01:18:38 PM »
Quote from: jacel86 on February 14, 2012, 01:13:19 PM
bolt holes supposedly don't line up..
jacel86
Free Loader
Reply #37 on:
February 14, 2012, 01:46:17 PM »
That's "boo" worthy!
Reply #38 on:
February 15, 2012, 08:44:59 AM »
i left the buddy heater in this thing last night to try and dry out the floors that are still sopping wet from whispering pines 2 weeks ago....
i shop vacuumed out a couple gallons of mud and sponge dried as much more as i could. I think its going to take a couple more days with the heater. lol
Reply #39 on:
February 16, 2012, 11:30:23 PM »
put the front end back in this thing tonight for hopfully the last time for a while. no one late stocks dana 30 inner axle seals, bah!
the case in this thing is fucked, pisses me off, it was working awesome at rausch and the pines.
Reply #40 on:
February 16, 2012, 11:53:02 PM »
I have that 231 and plenty of Dana 30 seals of you need...
Reply #41 on:
February 17, 2012, 07:18:52 AM »
ya, need 23 spline, and dont want to swap any parts because i think its got some warn or bad parts.
Free Loader
Reply #42 on:
February 17, 2012, 08:36:31 AM »
if the case happened to disappear from my TJ it would be more incentive to get moving on the rest...
Reply #43 on:
February 17, 2012, 08:40:47 AM »
i have a new chain kit if you want to fuck around with it
Reply #44 on:
February 17, 2012, 09:30:30 AM »
mine is a 231HD
bigger chain and main shaft is different
4
